moved_sea.inoAfter connecting we are ready to use the code so connect Arduino to your computer and upload the code in the attached code file.ino - 5.57 kB - 03/08/2017 at 20:36 |
DMD2.cppEnter to the DMD2 library and change the ( DMD2.cpp) with this one attached, it is only changed to work with mega different pins.cpp - 6.26 kB - 03/08/2017 at 20:35 |
