• Getting Better and Better
    Neil Mundt02/11/2025 at 00:16 0 comments
    Made it a Little bit larger. I want there to be good info-graphics on the routing of the circuit. So it adds a small learning about each section of the circuit. Adds to the Enjoyment. I think understanding each section of the Circuit is a good way to get people interested in Small electronic devices like this.
  • Second Go around for layout.
    Neil Mundt02/08/2025 at 04:44 0 comments
    Found a good way to do the Electro Caps to have them on the Flipside of the PCB. I will probably have an PCB as a backing on this one. While I like the idea of it not having aback like my APC card. I think it is better to have a PCB case or Back panel. It is getting close to a final layout. As you can see in my previous layout its quite a bit cleaner layout with the sections. Might still adjust the full size so I can fit more art on it and make it Easier to Understand the Sections. This is really shaping up nicely after Finishing my Vines Link Module.
  • First Layout For something
    Neil Mundt02/06/2025 at 20:43 0 comments
    The Layout is still very WIP. But the Bones are there. Still Need to overhaul the Schematic and refine the component count and figure out a way to do the Electrolytic caps. This one will probably have some sort of back to make this one more friendly.
