End Piece with Wire tensioner
A project log for Magnetostrictive Position Sensor
Hard- and Software for a position measurement sensor with a magnet and a magnetostrictive wire.
florian-bFlorian B. 03/05/2025 at 21:580 Comments
Sometimes it can be difficult to apply tension to a wire. So I created a very practical end piece:
The wire is clamped into the center of a moving block that has a M10 thread on the outer side.
With a hex nut the block can be moved outside to apply tension to the wire.
