List of features:
- M.2 slot with all pads on the board to accept any key slot M.2 module, if the correct connector is mounted.
- PCIe signals are routed as differential pairs.
- Specifically made for A key and E key, works with a subset of signals for B key and M key.
- USB-C set up for 5V 3A max power draw.
- Switching regulator to generate 3.3V 1.5A to power the M.2 module.
- 1.8V LDO regulator to be able to work with the 1.8V UART and I2C signals
- Power switch for the 3.3V to the M.2 module with an enable jumper
- LEDs for 1.8V, 3.3V and switched 3.3V
- No mounting holes :( , will be added to rev 2.
- Design in KiCAD 8.
- Hand soldered.
