The image displays the initial 3D model of the shooter, the core component of the system. The back of the shooter includes space for a small solenoid, positioned at the center of the ping pong ball. However, I later realized that a small solenoid lacks the necessary force to propel the ball effectively, especially when the shooter is tilted upward and gravity is working against it.
Aishat
