3D Model of Alternative Shooter with Servo Motor (instead of solenoid)
A project log for Beer Pong Robot
A beer pong robot that fires ping pong balls into red solo cups with manual and autonomous control. Pong, strong, shots all night long!
aishatAishat 03/18/2025 at 04:240 Comments
The image showcases an alternative 3D model of the shooter, with the primary difference being the back section. Instead of a small solenoid, this version includes a compartment for a servo. After realizing that the solenoid lacked sufficient force, I tested whether a servo with an attached servo horn could provide enough force to push out the ping pong ball whether the shooter is tilted upwards. However, this approach also proved ineffective. As a result, this model was not used as the final version. Nonetheless, experimenting with different designs and "pushing out" mechanisms was valuable in determining the best fit for the system's needs.
