The image depicts the final 3D model of the shooter. The main modification is the enlarged compartment at the back, designed to accommodate a larger solenoid. Neither the small solenoid nor the micro servo provided enough force to eject the ping pong ball when the shooter was tilted upward, making the larger solenoid the only viable option. Additionally, the compartments for the two DC motors were shifted slightly toward the back. This adjustment was necessary because, at times, the solenoid did not push the ball far enough, and positioning the motors closer to the back helped address this issue.
Aishat
