Inverted Pendulum Robot
A self-balancing inverted pendulum robot running on ROS 2, untethered, ~12 inches tall.
Public Chat
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
I will design an build a self balancing inverted pendulum robot that will run on ROS 2. I will start by implementing the software on a generic version in ROS and Gazebo to focus on learning the theory and skills companies seek, and later after refining hardware requirements from the simulation and modeling I will build the robot and implement the software on it. Eventually I would like to add a depth camera or LIDAR to incorporate perception based planning and obstacle avoidance.
