Color By Code
Create any paint color imaginable!
We made a custom-color paint mixer in a couple short weeks for a class prototyping project. This robot is designed to mix together Cyan, Magenta, Yellow, and Black acrylic paints to create any color based on user input. The motivation for this project is that painting is fun, but buying paint is not so fun -- different colors can become expensive quickly, especially if only small quantities are needed. Mixing colors manually is always an option, but who has time for that? Not to mention that it's nearly impossible to replicate a color that has been manually mixed once before if more is needed. Our solution to this problem is Color By Code, an Arduino + peristaltic pump powered custom paint mixer! Feel free to contact us at mfrida999@gmail.com with any questions or comments.
Brief Overview
We built an automated paint mixer that allows users to input custom Cyan, Magenta, Yellow, and Black (CMYK) color values (from 0–100%) and automatically dispenses the corresponding color amounts using peristaltic pumps. To maintain cleanliness and prevent clogs in the tubing, we implemented a multi-cycle water flushing system to start after the custom paint has been made and mixed using a magnetic stir plate. A reverse flow mechanism prevents residual paint from interfering with the paint ratios and minimizes paint waste. Currently, an Arduino Nano Every and a 12V batter supply powers the entire setup which is connected to a Macbook running the Arduino IDE commands.
Methodology
Calibrating Flow Rate
We began by connecting a single peristaltic pump to the breadboard to measure its flow rate. This step was essential for calculating the duration each pump needs to run in order to dispense the correct amount of liquid corresponding to the desired color composition.
Initial CAD Design
We designed and printed out a very basic CAD design, prioritizing functionality over aesthetics using Fusion360 to make the design and a Bambu Lab X1E 3D printer to bring it to life. The general shape was inspired by Keurig coffee makers, not because we were drinking a lot of coffee at the time, but because we thought the size and shape seemed very optimal for dispensing fluid and keeping the inner workings (the pumps and all) hidden. The design also required two separate prints which was perfect because the printers we used couldn't have held the entire body in one piece anyway.
Some specific features include:
  • Space to hold stir plate base
    • Hole in the front for knob
    • Tiny hole in the back for stir plate wire
  • Top container
    • Hollow interior to hold 4 pumps
    • Space on back for output tubes to enter CMYK bottles
    • Space on top of base body for input tubes to exit
    • "Color By Code" engraving on front and pump peep hole in front for funsies
  • Open top
    • Easy access in case of faulty wirings
    • We didn't add anything to cover the breadboard and wiring top because (1) it looks cool (2) it's a work in progress so it would be annoying to have to keep opening the top up to access wiring
  • Embossed "Color By Code" title was engraved using one of the built-in features of the Bambu Lab printers
Hardware
The two red driver modules are connected to each other and can support two pumps each. The 12V battery supply connects directly into one of the drivers and we mapped out the pinout connections to the code to control the flow directions of each motor. For space purposes, both red driver modules are placed on the breadboard using foam mounting squares.
The two pieces of the CAD design (the body and pump cover) are super glued together.
Each of the peristaltic pumps has additional tubing attached to each of the ends to extend the flow. The peristaltic pumps themselves are faced mirroring each other -- two face one direction and the other two face the opposite direction (see gallery image).
Software
All of the code was written and executed on Arduino IDE. To start, the code prompts for user input of CMYK values, then the specified amounts are dispensed into the output cup (currently based on the flow rate). Any leftover paint in the tubing is returned to the original paint containers by reversing the pump directions. Once this is done, there is a brief delay while we get ready for the flushing mechanism (swapping around cups). Then there are 5 cycles of water flushing before the program terminates.
Testing
To test the code initially, we used water and food coloring. This was a cheaper and neater alternative to wasting a lot of acrylic paint just to make sure the pumps were flowing in the proper direction (See gallery image).
Future Work
  • Bluetooth App
    • Replacing current microcontroller with one compatible with bluetooth
    • Making a mobile app that has a color grid so that people can pick CMYK colors from there
  • Paint Colors
    • For the final...
main_body.stl
Main part of the CAD body. Designed to secure the stir plate and provide a sturdy and level platform for the pumps to lie on. Has a hole along the top so that output tubing can exit discretely. *Printed with tree supports*
Standard Tesselated Geometry - 50.77 kB - 03/24/2025 at 03:42
Download
pump_cover.stl
Top part of the CAD body. Designed to contain the inner peristaltic pumps and keep them a mystery to the public. There is a pump window to peep into the container though for anyone who is curious on the layout. *Printed without any supports, flat side down*
Standard Tesselated Geometry - 19.03 kB - 03/24/2025 at 03:39
Download
  • 1 × Arduino Nano Every microcontroller
  • 4 × Peristaltic pumps + compatible plastic tubing
  • 2 × L298N motor driver board modules
  • 1 × 12V battery supply + adapter
  • 1 × Long breadboard
View all 9 components
  • To Be Continued...
    frida moreno03/24/2025 at 21:32 0 comments
    There will definitely be further updates because this is something we genuinely find interesting and practical. So stay tuned!
  • Winter Term CS12 Updates
    frida moreno03/24/2025 at 21:31 0 comments
    We didn't follow a weekly schedule organized enough to log on here without completely lying about our timeline, instead, it would be more accurate to categorize the work we completed for CS12 in two notable bursts of productivity:
    First Burst (Night before Critical Design Review)
    • Initial CAD body and pump cover printed out
      •  The initial CAD was very pointy and boxy so it was actually different than the one linked in files
    • Functioning pumps
      • Used food coloring for testing the pumps
      • Only tested blue and yellow pumps (foreshadowing our downfall)
      • Code was super basic
        • Pumps just ran infinitely forward until 12V battery supply unplugged
        • No liquid reversal (huge mess)
    • Took a video that didn't show a perfect paint mixer (in fact, we hadn't even tested with paint yet), but more importantly showed that it was possible!
    Second Burst (Night before Demonstration Day)
    • Code cleanup
      • Implemented pump reversal
      • Added 5 cycle water flush mechanism
      • Lots of timing stuff
    • Tested with paint for the first time
      • Now the flow rate was different
    • Blue pump would not reverse
      • Literally spent an entire day trying to debug this, got super irritated (I'm actually so sorry Asmat), only for it to be an off-by-one hardware-software mismatch in the Arduino pinouts
View all 2 project logs
