• IS COMPLETE!
    Michal03/20/2025 at 12:19 0 comments
  • Connection
    Michal03/04/2025 at 04:16 0 comments
    For external connections, these waterproof connectors are used. From left: USB-C, RJ45, 9pin I/O, 4pin for charging.
  • CPU
    Michal02/27/2025 at 06:11 0 comments
    The heart of the entire cyberdeck is the RPi4 with a massive passive heatsink, complete with a fan. The fan is switched on and off by the RPi itself based on temperature using a GPIO pin and a simple transistor switch.
  • Power management
    Michal02/26/2025 at 03:46 0 comments
    The main DC converter that generates 5.3V from the battery voltage to power most components. A voltage divider for monitoring battery voltage and an ACS712 module for current measurement are connected to the input.
  • More photos from the construction
    Michal02/22/2025 at 06:27 0 comments
    Layout of components in the lid. LCD for RPi, TFT LCD for Arduino and oscilloscope. In the upper right corner is the GPS receiver.
  • Battery management
    Michal02/15/2025 at 06:08 0 comments
    Assembled battery with BMS. The components are glued with 3M VHB double-sided tape, which also provides a gap for ventilation.
  • First photo from the construction
    Michal02/15/2025 at 05:03 0 comments
