Version 0.1 PCB
A project log for CM5 IO Board Fan Halt
Automatically stop the fan when shutting down your Pi Compute Module 5. Finally some peace and quiet!
eontronicsEontronics • 02/15/2025 at 23:30•0 Comments
This should be a fairly brief log covering some features of the PCB layout, with most technical aspects being discussed in the Version 0.1 Schematic log.
Front copper layer and component placement of Fan Halt Module
Components and copper are only on the front side of the board
3D Render of Fan Halt module
Quick 3D render to check everything looks right
The overall PCB dimensions are 15.5mm by 49.5mm, and is designed to fit in the gap between the Compute Module and M.2 slot on the Compute Module 5 IO board. Two cutouts are placed on the board to provide clearance for the JST-SH fan header on the IO board, and a small SOT23-5 component located a bit below it. A single mounting hole is shared with the IO board.
It is a single layer design, using only 2 1206 jumpers to allow the ground plane to pass beneath the power traces. Keeping the copper on a single layer was done for two reasons. Firstly, as there is no copper on the bottom, and no through hole components, there is no risk of accidentally shorting traces on the IO board should the soldermask be damaged, which allows the PCB to be installed directly onto the IO board. Secondly, it makes it easier for a hobbyist to manufacture the board at home, without needing to worry about alignment of a second layer, or fitting via 'rivets' to the board. Any internal fillet radii of the board outline are at least 0.5mm for milling, and all components are 0603 or larger, so everything can be hand soldered with a bit of care.
The location of the connector to the IO board is placed so that a 50mm long JST-SH cable (such as this one from Adafruit) is approximately the right length to connect to the IO boards fan header, without creating excessive bending of the cable or leaving too much loose wire. The module fan header is then located as closely as possible to the IO board fan header to keep fan wiring consistent.
A second fan connector using a standard surface mount 0.1" pitch pin header can be optionally soldered for connecting desktop PC fans, or to connect jumper wires to some other generic load to be controlled.
Since the single mounting hole shared with the IO board may not provide a secure enough attachment to avoid the module from working its way loose, notches were added to the bottom edge of the board to help combat this. These can either be used as alignment guides with a 3D printed bracket, or to provide additional surface area for silicone adhesive when mounted directly onto the IO board.
Image of Fan Halt Module with bodge wire to correct transistor pinout
A quick look at the actual module, notice Q1 has been rotated with an extra flying wire added to correct the pinout
Due to the error in the schematic, a small bodge was required to switch the pinout of the output transistor for the board to function correctly (i.e. actually turn off the fan, rather than just slow it down due to the voltage drop across the body diode!). I also noticed the AO3401A used for the output transistor has an absolute maximum gate-source voltage of 12V (not 20V like I thought!), which will be reached when running the module from a 12V supply. Both these issues should be fixed for version 0.2 of the board, which will hopefully be the only revision required!
Fan halt module installed on CM5 IO Board
I need to get the correct length wire, but otherwise not a bad fit!
