The Physics of Light: How Prisms Split a Spectrum
A project log for JASPER: VIS-NIR SPECTROMETER
Grating-based VIS-NIR Spectrometer: Customizable for spectral range, resolution, SNR, and detector options aided by a software design tool
tony-francisTony Francis 08/11/2025 at 19:340 Comments
One of the most classic scientific experiments is observing a prism split white light into a rainbow. The phenomenon, known as chromatic dispersion, is the physical principle behind many spectrometers. While prisms were a staple in early spectrometers, they have largely been replaced by diffraction gratings due to their limitations. A prism's ability to disperse incident light is a complex function of three key factors:
A spectrometer that uses a prism operates on the following principle: First, a lens is used to collimate the light, ensuring the light rays are parallel. This collimated light then passes through a narrow slit to create a well-defined, thin beam. This beam then strikes the prism face at a specific angle of incidence, i.
Due to the chromatic dispersion property of the prism material, the refractive index (n) is different for each wavelength of light. This causes each constituent color to refract at a slightly different angle, effectively splitting the white light into its individual spectral constituents. These separated wavelengths can then be viewed on a screen or captured by a detector array.
A key limitation of glass prisms is that the variation of their refractive index with wavelength is relatively small and non-linear. This results in poor dispersion and, consequently, low spectral resolution, meaning the device struggles to differentiate between closely spaced wavelengths. The optical resolution—a measure of the instrument's ability to resolve two adjacent spectral lines—dictates the required pixel size or interval for a line array detector. This, in turn, establishes the system's digital resolution.
As you can see in this demonstration of spectral dispersion using a white light LED and a prism, the resulting spectrum is not very sharp and the resolution is low.
The non-linear dispersion also means the spectrum is compressed at one end and stretched at the other, making uniform calibration difficult. This is precisely why commercial spectrometers rarely, if ever, employ a prism in their design today.
