The grating equation is a fundamental principle in optics that describes how light diffracts when it passes through a diffraction grating.
The simplest form of the grating equation, mλ=dsinβ, applies when light is incident normally (perpendicularly) on the grating. In this case, there is no angle of incidence to consider, and β represents the angle of diffraction for a given order m.
However, when the light is incident at an angle α to the grating's normal, the equation becomes more general to account for the additional path difference introduced by the incident angle. This leads to the modified grating equation, which is mλ=d(sinα±sinβ). The initial equation without the angle of incidence is therefore a special case of the modified equation where α=0.
Derivation of the Modified Grating Equation
The derivation considers the path difference between two rays of light incident on adjacent slits of a diffraction grating. The grating has a slit separation of d.
Path Difference Before the Grating:
Consider a plane wavefront incident on the grating at an angle α to the grating's normal. Let's look at two adjacent slits, A and B. A ray of light hits slit A, and another parallel ray hits slit B. Draw a line from slit A perpendicular to the incident ray at B. The path difference between the two rays before they hit the grating is the distance between B and this perpendicular line. This distance is dsinα.
Path Difference After the Grating:
The diffracted rays leave the grating at an angle β to the normal. Again, consider the two rays leaving slits A and B. Draw a line from slit A perpendicular to the diffracted ray at B. The path difference between the two rays after they leave the grating is the distance between B and this second perpendicular line. This distance is dsinβ.
Total Path Difference: The total path difference for the two rays is the sum of the path differences before and after the grating. Total path difference = dsinα+dsinβ. For constructive interference (a bright fringe or maximum), this total path difference must be an integer multiple of the wavelength, λ. This is expressed as mλ. Therefore, the modified grating equation is mλ=d(sinα+sinβ).
Explaining the Sign Convention (sinα±sinβ)
The sign of the sinβ term depends on the direction of the diffracted light relative to the incident light. The standard sign convention defines angles as positive or negative based on which side of the grating normal they are.
- Case 1: Positive Sign (+) This occurs when the incident angle α and the diffracted angle β are on opposite sides of the grating normal. In this scenario, if you define the incident angle α as positive, then the diffracted angle β will also be positive, and the equation is mλ=d(sinα+sinβ).
- Case 2: Negative Sign (− or ±) This occurs when the incident angle α and the diffracted angle β are on the same side of the grating normal. Using the same sign convention, if the incident angle α is positive, the diffracted angle β is considered negative. Since sin(−β)=−sin(β), the equation becomes mλ=d(sinα+sin(−β)) which simplifies to mλ=d(sinα−sinβ). This is why the general form of the equation is often written with a "±" sign, where you subtract if the angles are on the same side of the normal
The sign convention for the modified grating equation is hard to comprehend. We should attempt a design of experiment comparing the theoretical prediction of diffracted angles and the practical measurement for a practical case using a known grating. This will help us better understand the sign convention and validate the theory
Tony Francis
