Groove Spacing and Validation: Initial Experiments
A project log for JASPER: VIS-NIR SPECTROMETER
Grating-based VIS-NIR Spectrometer: Customizable for spectral range, resolution, SNR, and detector options aided by a software design tool
tony-francisTony Francis 08/21/2025 at 19:010 Comments
At the heart of a grating is its groove spacing, the microscopic distance between each of its parallel lines. This spacing is a crucial factor that determines the grating's performance.
To give you an idea of the precision required, let's consider some common grating types. A typical grating for a visible-light spectrometer might have 1200 grooves per millimeter. That's a groove spacing of about 833 nanometers, a distance smaller than the wavelength of some infrared light! To manufacture something this precise, companies use advanced techniques like holographic lithography, where lasers are used to create an interference pattern on a photosensitive material, or mechanical ruling, which uses a diamond-tipped tool to etch grooves.
But how do we know if our grating is up to spec? We can't just take the manufacturer's word for it. One way to validate the groove spacing is by using a laser with a known wavelength and the grating equation =dsinθm. By measuring the angle of the diffracted light, we can solve for the groove spacing, d. This simple test gives us confidence that the grating will perform as expected in our spectrometer.
The Blazing Problem and the Ghosts in the Machine
A key feature we're also concerned about is the blaze angle. This is a strategic tilt in the groove profile that directs the most light into a specific diffraction order. Inconsistencies in this angle can lead to unpredictable changes in our spectrometer's efficiency, a serious problem for accurate measurements.
Beyond the blaze angle, gratings can suffer from ghosts—faint, false spectral lines caused by tiny, periodic errors from the manufacturing process. While these are typically weak, they can be a real headache in high-precision work. For now, we're relying on the manufacturer's quality control, but it's important to be aware of these potential pitfalls as we develop our spectrometer.
Our Grating Validation Experiment
To get a hands-on feel for our gratings, we conducted a simple experiment. Our goal was to compare gratings from the same batch to see if they were consistent. We set up a rig to illuminate the entire surface of a grating with collimated light and then captured the resulting spectrum.
By repeating this with several gratings from our batch, we can inspect a specific diffraction order and look for similarities. To make sure our comparisons are valid, our next step is to create an identical measurement system for each test. This simple, visual check gives us a high-level sense of the grating's quality and consistency.
Ultimately, even the best grating will have minor imperfections. That’s where our design and calibration come in. By developing a robust calibration procedure, we can compensate for these small errors, ensuring that our final spectrometer is both precise and reliable
Future Validations
With a well-characterized light source like a mercury lamp or a laser, and a detector, we can validate  gratings. For future high-precision work, a possible setup would involve a scanning grating system where the grating is mounted on a highly precise rotation stage. The detector would remain stationary, and by scanning the grating, we could map out the diffracted spectrum. This approach would allow us to detect imperfections like ghosts or inconsistencies in the groove spacing. The key challenge, as we’ve noted, is that the precision of our measurement system must be an order of magnitude higher than the errors we're trying to find in the grating itself. This is a project for a future stage of our lab, but it's an important capability to consider.
