In our previous post, we introduced the fundamental concepts behind spectrometer design, focusing on two primary conventions for the grating equation: the fixed geometry approach and the Littrow condition. We explored how these conventions dictate a spectrometer's performance and physical characteristics. If you haven't read it yet, you can find the first part of this series here: Spectrometer Design: Choosing the Right Geometry for VIS-NIR Spectroscopy.
This blog will now delve into the practical application of those conventions by examining the block diagrams of two popular spectrometer designs: the Czerny-Turner and the Lens Grating Lens (LGL) configurations. Understanding these layouts is key to translating theoretical equations into a functional instrument.
The Czerny-Turner Configuration
The Czerny-Turner configuration is a workhorse in spectroscopy, widely used for its excellent performance over a broad spectral range. It's a prime example of a design that follows the fixed geometry convention (Φ=α+β).
As shown in the diagram, a Czerny-Turner system uses two mirrors to manage the light path. Light enters through the optical slit and is collimated by the first spherical mirror, the Collimation Mirror. This collimated beam then strikes the diffraction grating. The grating separates the light into its constituent wavelengths, and the diffracted light is then focused by a second spherical mirror, the Focusing Mirror, onto the Detector Array. The key takeaway is that the light path deviates after the grating, and this fixed deviation angle is a critical parameter in the design. The use of two mirrors allows for precise control of aberrations, leading to high-quality spectral data.
The Lens Grating Lens (LGL) Configuration
In contrast to the Czerny-Turner, the LGL configuration often utilizes the Littrow condition (α=−β) and is a prime example of a transmission-based system.
In the LGL setup, the two spherical mirrors of the Czerny-Turner are replaced by lenses. Light enters through the slit and is collimated by the Collimation Lens. The collimated light then passes through the transmission diffraction grating, where the light is separated by wavelength. Finally, the Focusing Lens focuses the diffracted light onto the Detector Array. Since this configuration often operates close to the Littrow condition, the optical path is straighter and more compact than in the Czerny-Turner. This design is excellent for applications where a small form factor and cost-effectiveness are critical, though it may sacrifice some of the aberration control found in more complex designs.
Connecting the Theory to the Block Diagrams
The block diagrams clearly illustrate the differences between the two design conventions discussed in the previous blog. The Czerny-Turner's two-mirror system and folded light path directly reflect the fixed deviation angle of Convention 1. The LGL's more linear layout, using lenses and a transmission grating, is a practical implementation of the Littrow condition, which aims to minimize the light path deviation.
Understanding these optical configurations is the next crucial step in designing a high-performance spectrometer. We will continue this series by diving into the specifics of deriving the angles for Convention 1 and how they apply to the Czerny-Turner geometry.
Tony Francis
