Going low
02/19/2025 at 01:38 • 0 commentsI have ported the code to ATTiny85. To make a long story short, the first version
hat could fit the Digispark used 99% of flash
The second version calling functions that dealt with PROGMEM and using tiny versions for RTC, neopixel and I2C (wire) libraris still took me 95% of the flash.
I have then replaced the Wire and RTC libraries with my own code and now the sketch takes 87% of the flash.
There's still some room for improvements, but that's good enough! for the moment.
Sources available at project's Github repository
Flip mode test
02/18/2025 at 00:49 • 0 commentsThis video shows the flip mode.
When in Cistercian mode, a short press on the button will display the time in decimal mode (flip)
