Hackaday.io Hackaday.io
Sign up Log in
LO-FI Legacy Looper
An In the Pocket Voice Recorder Based of the ISD1820 Recorder IC.
neil-mundtNeil Mundt
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
1 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
117
0
1
1
Team (1)
  • neil-mundtNeil Mundt
Join this project's team
hardware
ongoing project
Synth card stem eletronics eurorack modular
This project was created on 02/17/2025 and last updated 25 days ago.
Description
ISD1820 Recorder circuit Individual Output Gate Trigger? CV
Project Logs
Collapse
  • Been Fixing up the PCB layout and artwork.
    Neil Mundt • 10/13/2025 at 20:47 • 0 comments
    Been Messing around with the layout and tracking down a 2 x Coincell battery holder for the samplers power supply. Loving the layout so far. Rounded corners and Slightly larger then I thought it would end up, but it looks pretty nice so far.
  • Getting The Basic Layout Down.
    Neil Mundt • 08/14/2025 at 19:29 • 0 comments
    Been Chipping away at this PCB. Finalised the layout is pretty much done. I really liked how the layout turned out. I like to think that this combines a cross between the PatchMate: Power Transmission Chip style and that I tired to Make with my First complete Project the Atari Punk Console Semi-Patchable SynthCard
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
I made this dual channel stereo 28watt amplifier in on a small cute PCB, Powered by external 18v dual power supply and has very good audio.
Project Owner Contributor
TDA2030 Amplifier Has Amazing Performance
sagar-001Sagar 001
I came across a schematic of a reverse engineered 12V - 120V AC Power Inverter. So I started to make the "ONE BAD A$$ POWER INVERTER.
One Bad A$$ Power Inverter
fredkonofredkono
A BreadBoard Compatible Eurorack Power Input for prototyping Synth Circuits
PatchMate:Power Transmission
Hi guy today we make220V to 24V 15A | Power Supply | Switching Power Supply.
220V TO 24V 15A | POWER SUPPLY | SWITCHING POWER
youkito1991youkito1991
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "LO-FI Legacy Looper", please tell us the reason.
Send message
Remove Member
