NarvalO
(High Speed) RC Boat using plywood
In the following section, you're gonna discover how to build a RC Boat that goes pretty fast !! This is a group project divided in 12 sessions, each session during 3 hours.
The electronical system is based on ESP and the main material is plywood.
Hope you have fun !!
Here is the advancement on week three of the hull design
  • week 4
    edgar.febvin03/12/2025 at 16:05 0 comments
    Today we finished the Fusion model but the wood we used for the laser cuter was too resistant to bending so we're going to use kerf bending Technics. On the motor part we ended up on brush less for the water resistance.
    Diamètre : Ø35mm
    Longueur : 34mm
    Tours par volt (KV) : 1200
    Puissance : 475W
    Diamètre de l'arbre moteur : Ø4mm
    Poids : 109g
    Type de moteur : brushless à cage tournante (outrunner)
    Consommation de courant max. A : 37A
    Recommandation de batterie : 2S ou 3S LiPo
    and we'll use propellers for propultion,
    We have two choice for directions, either we use a servomotor of we use two brushless that we activate alternatively. Because we already have the servo we just have to command the brush less motors.
    Днес завършихме модела Fusion, но дървото, което използвахме за лазерния резач, беше твърде устойчиво на огъване, така че ще използваме техника за огъване на бордюри. По частта на двигателя завършихме с по-малко четки за водоустойчивост.
    Диаметър : Ø35mm
    Дължина: 34 мм
    Мощност: 475W
    Тегло: 109g
    Тип на мотора : безчетков с турнантна клетка (outrunner)
    И ще използваме витла за задвижване,
    Имаме два избора за посоките, или ще използваме сервомотор, или ще използваме два безчеткови двигателя, които ще активираме алтернативно. Тъй като вече имаме сервомотор, трябва само да командваме двигателите без четки.
  • week 3
    edgar.febvin03/05/2025 at 16:03 0 comments
    Today we did advance on two axis, first the hull model. With a new scrappy desing and some fusion sketches we got a pretty good view at the V1 of the project.
    We also advanced on the motor axis, finding a model that can help having speed torque while being waterproof. The model we choose is a
    Moteur Brushless RO-POWER TORQUE 3534 1200kv ROBBE
  • 둘째 주
    Georges Fayad02/26/2025 at 15:54 0 comments
    두 번째 주에 인터넷에서 기존 설계도를 검색했지만 사용할 수 있는 설계도를 찾지 못했습니다.
    We started our second week by looking for existent blueprints on the web, but couldn't find any that were relatable.
    그러다가 Fusion 360을 사용하여 한 쪽에서는 엔진 작업을 하고 다른 쪽에서는 선체 스케치를 하면 작업을 더 효율적으로 나눌 수 있다는 사실을 깨닫고 직접 시도해 보기로 결정했습니다.
    We then decided to try it ourselves when we realised that we could actually divide our work more efficiently by working on the engine, on one part and sketching the hull on the other, using Fusion 360.
  • Primera Semana
    Georges Fayad02/26/2025 at 15:14 0 comments
    ii Hola a todos !!
    Hello everyone !!
    Durante la primera clase, hemos realizado nuestro primer intento de proyecto utilizando cartón. Fue bastante difícil ya que no teníamos ni idea de cómo hacerlo, pero aún así encontramos una manera de concretarlo al final, como se muestra a continuación :
    During the first class, we have made our first project attempt using cardboard. It was pretty hard since we had no clue how to make it, but still found a way to concretize it at the end, like shown below :
    Usamos un poco de pegamento para hacerlo mas fuerte, y curvamos el carton para que pareciera un verdadero barco de rc. Desgraciadamente, con lo tontos que somos, lo pusimos en agua para ver si flotaba, pero el barco se ahogo debido a que el carton absorbia agua, y asi perdimos nuestro prototipo.
    We used a few gluestick to make it stronger, and curved the cardboard to make it look like a real rc boat. Unfortunatley, as stupid as we are, we put it on water to see if it floats, but the boat drowned due to the coardboard absorbing water, and so lost our prototype.
    Aún así, nos dimos cuenta de que la forma del barco estaba bien, y que teníamos que trabajar en ella, y probablemente dibujar primero un plano 2D para poder imprimirlo.
    We still learnt that the shape of the boat was fine, and that we need to work on it, and probably sketch a 2D blueprint first in order to print it.
View all 4 project logs
