Day 7: Final Assembly and First Movement Test
A project log for WALL-B Robot
Inspired by the famous WALL-E, our team is building WALL-B, an autonomous robot designed to detect and remove objects from its path.
yousufhosnyyousuf.hosny • 05/26/2025 at 14:13•0 Comments
After days of cutting, assembling, wiring, and debugging, Day 7 marked a huge milestone:
We started the session by attaching the final wooden panels and ensuring all components—motors, wiring, and electronics—were securely mounted inside the chassis. The track system was finalized and aligned with the drivetrain. Once complete, WALL-B stood fully assembled and ready for testing, as you can see in the photos.
