A project log for Design for disability - Fork adapter
maxenceperrot80maxenceperrot80 04/08/2025 at 08:540 Comments
We continued working on the different part that we each had to do, some more prototypes were made for the snap fit, we think we are going to go with the 3rd design (see the screenshot of fusion), which was inspired by a snap fit buckle (see example of the inspiration), the creation of the gloves has also began (take a look at the photo), we now have to do a fork that will fit the snap fit, our idea would be to make a 7cm fork, including its handle, which would correspond to the snap fit created, we will see if it works, but it might not be resistant enough. The way the fork would be put inside the snap fit, would be to put the fork in an adaptative handle that can be put in and out of the snap fit.
