Celenn did a glove prototype. The snapfit base is finished, we did 2 handle prototypes that can goes inside the snapfit, we will try them during the next lesson to see which one is the most comfortable to use, but also to see if they resist well, after that we'll make a hole inside the handle to insert a fork, to make it easier to wash, but also usable with more objects if possible, or if there is a problem, we will change a part of the design.
