11. Measure the User's Hand
Measure palm width, hand length, and wrist circumference.
Ensure a snug fit while allowing for future growth (especially for children).
22. Sew the Glove
- Cut two glove-shaped pieces from the stretchable fabric with seam allowance.
- Sew along the edges (right sides together), leaving the wrist area open.
- Turn the glove inside out.
- Add soft padding inside if desired for comfort and to reduce pressure points.
33. Prepare the Snap-Fit Holder
- 3D print the custom snap-fit part using the provided STL file.
- Choose a fork of the user’s preferred size and shape (standard store-bought metal or plastic fork).
- Insert the fork handle into the inner cavity of the snap-fit part.
- Apply strong adhesive (such as epoxy or super glue) to permanently bond the fork to the holder. Allow adequate curing time as specified by the adhesive manufacturer.
4 4. Attach the Snap-Fit to the Glove
- Carefully identify the optimal fork position on the glove (usually above the palm or thumb area).
- Secure the outer shell of the 3D-printed holder to the glove using:
- Heavy-duty stitching through anchor holes (if present), or
- Fabric-compatible adhesive plus reinforcement stitching around the base
- Ensure the snap-fit part is tightly fixed to the glove so it does not rotate or loosen during use.
55. Test & Adjust
- Have the user wear the glove and test the fork in cutting motions.
- Adjust positioning or add reinforcement if necessary.
- Ensure comfort, freedom of movement, and utensil stability.
