Replica of the PDP-1: PiDP-1
Blinkenlights and vectordot graphics from 1959
Starting from
has orders / reviews
Ships from
The DEC PDP-1 was, in many ways, at the root of modern computing: interactive - with keyboard and graphics display. It spawned spacewar, the very first computer video game; teco, the first text editor; and the interactive debugger (DDT). Despite its tiny brain, it pioneered time-sharing, and was at the origin point of Arpanet: IMP code was written on a PDP-1, and a PDP-1 sent out software updates to the IMP routers across the net. More importantly, it spawned Hacker Culture. And today, it is a great retro platform for graphics demos. The Type 30 display was an odd mix of vector and pixel display, and coding for it is remarkably simple. Angelo and I decided to make a replica driven by a innovative type of emulator: though ported to C, it does not emulate the machine at the logic level, but on the circuit level. Main site: obsolescence.dev/pdp1.html
The PiDP-1 comes out of a loosely organised group of computer history hobbyists. In various cooperations, we did a PiDP-8, -11, and last year, a PiDP-10. They all share the idea of being a 'computer history capsule': a functional replica that should provide a realistic experience of how it felt to operate these historical machines, with their Blinkenlights - front panels - to debug, monitor and even program them. But also, with a curated software archive built-in that preserves as much of their software history as possible.
The PiDP-1 is done different in one respect - the simulator underneath still runs on a Raspberry Pi, but simulates the original system on a much lower level, that of the circuitry. It makes the simulation much slower. But then, the original ran at the equivalent of 0.2Mhz, so speed is not an issue.
But there is a purpose for this level of simulator detail: once you 'get' the PDP-1, you'll see it is a great retro platform for demo coding. There is fun to be had with running the world's first computer video game, spacewar. Some of the original graphics demos are enjoyable, as is playing around with the historical software tools that have been preserved. Nevertheless, hacking together a simple graphics demo or backporting a modern video game is very satisfying.
With the PDP-1 team at the Computer History Museum, we want to invite hackers and democoders to look at the PDP-1 - with the best of their code being run on the only real PDP-1 still alive at the CHM. With that goal in mind, we better make sure there is absolute fidelity in the PiDP-1's simulation...
hackaday-case-example.kicad_pcb
Example case made of solderable PCB panels, perhaps this is useful for other projects, as it contains the trial-by-error optimum for press-in slots, solder point placements etc., that we derived for the PiDP-1 case, taking into account PCB manufacturing tolerances (router drill bits are not always identical, which causes you to seek the safest best-fit...)
kicad_pcb - 429.32 kB - 03/02/2025 at 17:08
Download
  • 1 × Raspberry Pi Zero W recommended, other Pi's are fine as well
  • 1 × UDN2981 Driving LEDs with extra oomph
  • 1 × 74HC138 Electronic Components / Misc. Electronic Components
  • 1 × 74HC238 Logic ICs / Decoders, Encoders, Multiplexers, Demultiplexers
  • 58 × 4148 diodes One per switch, plus some more for spacewar controllers
View all 8 components
  • A PDP-1 Agent? A hacker replicant!
    Oscarv • 10/04/2026 at 12:44 • 0 comments
    For computer history preservation, might replicant Hackers become as important as replicas of their machines?
    We replaced the old AI features with a full-fledged Hacker Replicant that you can install as an add-on onto the PiDP-1:
    You can now install Agent-PDP1 as an add-on to the PiDP-1 (or, of course, any other Linux machine). This project gives you an old MIT hacker sitting next to you as tutor, guide, programmer. It has access to typewriter, front panel, and can see the Type 30 display. We suggest you call him Ben, for historical reasons.
  • Living with Vintage Lisp
    Oscarv • 07/02/2026 at 21:23 • 0 comments
    Or maybe, experiencing Vintage Lisp. The PDP-1 Lisp had a remarkable origin story. Not only was it quite a feat to get any Lisp on a machine as puny as a 4Kw PDP-1, the REPL concept was invented along the way too. By Peter Deutsch, at the time a high school student who got himself behind MIT's PDP-1.
    The odd thing is - it is quite enjoyable to use even today. Once you figure out the little front panel intricacies. We did a write-up here:
    https://obsolescence.dev/pdp1-lisp-introduction.html
  • A 1960s PDP-1 Cyberdeck
    Oscarv • 03/12/2026 at 22:41 • 1 comment
    A picture of the setup Angelo and I used this week for a PiDP-1 development sprint:
    This was our home base for a great week. Bill Ezell has added cool things like drum storage and character generators to the PiDP-1, we had work to do. Also, the leftmost PiDP-1 can be seen with only 12 bits active. This is our new easter egg in the PiDP-1: it has a hidden PDP-5 mode starting next week.
    Due to Mike Hill coming to visit with a very intriguing 4 instruction Blinky demo program:
    PDP-5 coding on the PDP-1 is reasonable
  • Paleogaming!
    Oscarv • 02/18/2026 at 19:53 • 0 comments
    Before retrogaming came paleogaming. The video and terminal games written before the arrival of the microprocessor (yuck) - they are known by name by gaming history enthusiasts, but not many have tried them. Spacewar, Lunar Lander, Star Trek, the original Colossal Cave and Adventure.
    We want to add a paleogaming mode to the PiDP-1, where all of these games boot up quickly, ready to play without any setup hassle. Work starts in two weeks. It will require PDP-10/11/8 and even Whirlwind simulators installed in the PiDP-1 innards, and some simh scripting to make it all work flawless.
    But then, we will look at the PiDP-1 as the one and only paleogaming console :-)
    To be continued!
  • The first batch of 200 has gone out!
    Oscarv • 09/29/2025 at 01:35 • 0 comments
    Well, almost. We're shipping 5-6 PiDP-1s per day at the moment, working our way through the waitlist of daring early adopters. Thank you, all of you! We really, really appreciate the confidence.
    Now, we're waiting for parts to make the next 300. Over on the PiDP-1 Google Group, the fun has started. So far: a new disassembler, a new cross-assembler, a Forth and a Lisp (in Forth amazingly) have been written, plus a toolbox to inspect and convert paper tape images.
    We've gotten Lisp to work, and the standard development suite of Expensive Typewriter (oops, Symbolic Tape Editor in DEC's own words), MACRO and DDT.
    And work is underway to hook up modern I2C peripherals.
    We're having fun! You do not need to have the PiDP-1 hardware to join in, the virtual front panel version works just fine on a Pi, Linux laptop or even Windows WSL2: PiDP-1 Github repository. Please come and join the fun. Plenty of software archaeology left to do (who will bring up FORTRAN?)
  • Making a pretty case out of PCB panels
    Oscarv • 08/08/2025 at 06:28 • 0 comments
    I think this little video is interesting for more than just vintage computer fans: it shows how we made a very complex-shaped case out of just PCB panels. It took a lot of experimentation (see earlier log posts) but it works extremely well. The end result is a case that is so strong, you can drop it from 5 feet on a concrete floor. We tested that, although not on purpose.
    Here is the video:
    ...And look further down in the log posts for technical details. Perfecting this trick saved us a small fortune (which the budget actually did not allow for) compared to other case-building techniques like injection molding (yuck).
    Meanwhile, we're busy packing up the first 200 kits :-)
  • It's done! We're making PiDP-1 kits
    Oscarv • 08/06/2025 at 05:06 • 0 comments
    It took much longer than expected, because of recurring logistical trouble. There's a lot of parts in the PiDP-1, and that made it a real logistical nightmare. Custom-designed aluminum profiles were one challenge.
    But: It's done. We started making PiDP-1 kits today!
    Here is the smaller of the two variants we designed, the PiDP-1 Console, Does it look like a retro games console? That is the plan. We're starting to write some new games for the machine. The type 30 vector display is very fun to code for.
    So, the hardware development has come to an end. Now comes the real fun: reviving the 1959 PDP-1 with a hopefully active community of users and programmers. For the latter, we're writing a book. "Democoding on the PDP-1: A gentle introduction". Because this was the original democoders' machine, and if it is up to us, it will be again.
  • Into production! And book publishing?
    Oscarv • 06/22/2025 at 15:59 • 1 comment
    An update - all parts to make 200 PiDP-1 kits have been ordered. We were forced to use sea container shipping to keep costs under control. Things like the custom aluminum frame are heavy - but so is shipping all the PCB parts for 200 kits: the case is constructed from FR4 PCB material, giving a nice chunky weight to our little replica - but alas, shipping spoils the fun a little bit :-)
    We're now focusing on polishing up the software, and on writing a PDP-1 programming manual. Ambitiously called "Democoding for the PDP-1: A Gentle Introduction". Four of us started making some appealing graphics demos with fully commented step by step source code. This will be fun!
  • Finished the first test batch of 5 machines
    Oscarv • 04/05/2025 at 18:03 • 6 comments
    In other words, we increased the number of PDP-1s ever produced by 10% in two days :-)
    Lots of polishing up still two do. We're hiding from the world for two weeks to get it all done. Probably <i>almost</i> all done. <i>Mostly done.</i>
  • Spacewar controllers and Feature Creep
    Oscarv • 03/15/2025 at 01:04 • 0 comments
    So, we want to make the PiDP-1 a very affordable kit to make. Because, the more affordable the more chance that it will find its way to young coders who want to try their hand at PDP-1 programming!
    But we're battling feature creep, we'll just have to add two spacewar controllers. The idea is to make it them tiny, low-cost PCBs that will do the job on their own, but at the same time, can be the PCB inside a proper custom-made wooden spacewar control box. As the original ones were all quite visibly one-off jobs too, a proper spacewar controller must look - artisanal.
    But for those who do not like to tinker, they can use the PCB as-is:
    As we had 36 extra IOs for lights or switches, we did spend the whole day thinking of other exotica to add. For instance, the three PDP-1s that made it onto Arpanet had extra button boxes - the time-sharing operating system used them to hook up multiple Teletypes.
    But we decided against such things, they can all be done in software and the kit is already a package of 15 PCBs as it stands. And though PCBs are cheap, it does add up.
View all 16 project logs
Oscarv wrote 02/16/2026 at 17:07 • point
Michael, kudos to your for being the premier PDP-1 democoder of the 2020s! In March, Angelo and I will spend a week or so fulltime on polishing up the PiDP-1 with all the cool stuff that has emerged over the past months with the 'Batch Zero' issue of PiDP-1s. If we can have permission to add your Lunar Lander?
Michael Gardi wrote 02/16/2026 at 19:25 • point
Of course Oscar. I’d be honored for Lunar Lander to be part of the next release.
Michael Gardi wrote 02/14/2026 at 16:59 • point
Kudos to Oscar, Angelo, and the rest of the Obsolescence Guaranteed team. The PDP-1's historical significance is undisputed and the PiDP-1 lets you immerse yourself into that world. The kit is great fun to build and even more fun to program. There are only about 56 unique assembler instructions needed to program a basic PDP-1 with a standard Type 30 Display.  I had not written any assembler code since the 80s and had no trouble getting back into the flow. Highly recommended.
