• FTP anyone?
    Akasaka Ryuunosuke05/30/2025 at 08:43 0 comments
    More of a proof of concept than anything else, the thing crashes too much and the FTP client library needs quite a bit of work in the error handling department. But it does kinda play from my NAS!
  • Version 1 wrapped up
    Akasaka Ryuunosuke05/16/2025 at 02:33 0 comments
    The case is done, the software doesn't crash most of the times, I think that's good enough to call it complete for the time being! More photos under the cut.
  • The case taking shape
    Akasaka Ryuunosuke03/20/2025 at 14:01 0 comments
    At first I wanted to make a case out of sheet aluminium, custom made at a local case manufacturer.
    Then I thought maybe I need to just 3D print something, 'cause of course I didn't buy the IPEX-equipped ESP32s this time so WiFi won't pass through the aluminium.
    (Here's the Onshape workspace, by the way, in case you need the PCB sizes or a decently accurate SFF-spec CD-ROM drive size model)
    But in the end, ultimately, I just bought a bunch of MDF sheets that looked like they were a suitable size, and some corner brackets which happened to fit perfectly, and here I am again making a 1970s case for a 1990s device rebuilt in 2025.
  • A detailed look at the ESP32 based CD Player
    Akasaka Ryuunosuke03/11/2025 at 13:58 0 comments
  • Last.FM Scrobbling and menus and stuff
    Akasaka Ryuunosuke03/07/2025 at 14:01 0 comments
    Well that's just wonderful. A CD player that scrobbles my discs directly to my Last.fm account! :P
    I'm starting to lose momentum and use AI generated code for this. Albeit I think it's not awful, but not good either. You can find the commit in the WIP github: https://github.com/vladkorotnev/cd-player/commit/4ed21f539889a2d5c68b7d00df741be7b8e5ac7d
    Then again, the whole menu system is horribly unoptimized (allocate all things on the stack then copy, copy, copy!!), and yet it's completely human, no AI used! :P
    Maybe one day I'll have the energy to fix it, for now I just wanna have a working thing!!
    On which note it's mostly done I think, with the WiFi settings menu now in place. The only remainder is the radio URL input and selecting the CD track by number, and we're done!. Program playback, etc, maybe some day, but not for the first release.
