Harambe ain't dead
A project log for dBSound Bracelet
This project aims at protecting people's hear when they are under exposure of loud noises such as a live music concert or nightclubs.
dbsound-braceletdBSound Bracelet 05/11/2017 at 12:010 Comments
Hello, everyone we thought it was time for a complete log since the two previous ones were quite small. Please, take note that that you can now find the Source Code in the shared files and that the components list has been updated too.
Let’s look at the code, I want to make sure that everyone understands it. So, I hope that it could be improved in the future.
#include <Adafruit_NeoPixel.h>
#define PIN 6
#define NUM_LEDS 1
#define BRIGHTNESS 50
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, PIN, NEO_GRBW + NEO_KHZ800);
byte neopix_gamma[] = {
    0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,
    0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  1,  1,  1,  1,
    1,  1,  1,  1,  1,  1,  1,  1,  1,  2,  2,  2,  2,  2,  2,  2,
    2,  3,  3,  3,  3,  3,  3,  3,  4,  4,  4,  4,  4,  5,  5,  5,
    5,  6,  6,  6,  6,  7,  7,  7,  7,  8,  8,  8,  9,  9,  9, 10,
   10, 10, 11, 11, 11, 12, 12, 13, 13, 13, 14, 14, 15, 15, 16, 16,
   17, 17, 18, 18, 19, 19, 20, 20, 21, 21, 22, 22, 23, 24, 24, 25,
   25, 26, 27, 27, 28, 29, 29, 30, 31, 32, 32, 33, 34, 35, 35, 36,
   37, 38, 39, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 50,
   51, 52, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 66, 67, 68,
   69, 70, 72, 73, 74, 75, 77, 78, 79, 81, 82, 83, 85, 86, 87, 89,
   90, 92, 93, 95, 96, 98, 99,101,102,104,105,107,109,110,112,114,
  115,117,119,120,122,124,126,127,129,131,133,135,137,138,140,142,
  144,146,148,150,152,154,156,158,160,162,164,167,169,171,173,175,
  177,180,182,184,186,189,191,193,196,198,200,203,205,208,210,213,
  215,218,220,223,225,228,231,233,236,239,241,244,247,249,252,255 };
const int analogPin = A1; // Mic pin
int delta = 0;
void setup()
//Serial.begin(300);
strip.setBrightness(BRIGHTNESS);
strip.begin();
strip.show();
rainbowFade2White(3,3,1);
void loop()
int mn = 1024;
int mx = 0;
for (int i = 0; i < 500; ++i) {
int val = analogRead(analogPin);
mn = min(mn, val);
mx = max(mx, val);
//This is mostly used for calibration, the values don't really have to be displayed
//Serial.print("Min=");
//Serial.print(mn);
//Serial.print(" Max=");
//Serial.print(mx);
//Serial.print(" D=");
//Serial.print(mx-mn);
//Serial.println();
delta = map(mx-mn, 0, 1024, 0, 255);
//Serial.println(delta);
if(delta > 150)
  colorWipe(strip.Color(255, 0, 0), 50); // Red
  colorWipe(strip.Color(0, 0, 0, 0), 50); // White
else{
  colorWipe(strip.Color(0, 255, 0), 50); // Red
void colorWipe(uint32_t c, uint8_t wait) {
  for(uint16_t i=0; i<strip.numPixels(); i++) {
    strip.setPixelColor(i, c);
    strip.show();
    delay(wait);
void rainbowFade2White(uint8_t wait, int rainbowLoops, int whiteLoops) {
  float fadeMax = 100.0;
  int fadeVal = 0;
  uint32_t wheelVal;
  int redVal, greenVal, blueVal;
  for(int k = 0 ; k < rainbowLoops ; k ++){
    for(int j=0; j<256; j++) { // 5 cycles of all colors on wheel
      for(int i=0; i< strip.numPixels(); i++) {
        wheelVal = Wheel(((i * 256 / strip.numPixels()) + j) & 255);
        redVal = red(wheelVal) * float(fadeVal/fadeMax);
        greenVal = green(wheelVal) * float(fadeVal/fadeMax);
        blueVal = blue(wheelVal) * float(fadeVal/fadeMax);
        strip.setPixelColor( i, strip.Color( redVal, greenVal, blueVal ) );
      if(k == 0 && fadeVal < fadeMax-1) {
          fadeVal++;
      else if(k == rainbowLoops - 1 && j > 255 - fadeMax ){
          fadeVal--;
        strip.show();
        delay(wait);
  delay(500);
  for(int k = 0 ; k < whiteLoops ; k ++){
    for(int j = 0; j < 256 ; j++){
        for(uint16_t i=0; i < strip.numPixels(); i++) {
            strip.setPixelColor(i, strip.Color(0,0,0, neopix_gamma[j] ) );
          strip.show();
        delay(2000);
    for(int j = 255; j >= 0 ; j--){
          strip.show();
  delay(500);
uint32_t Wheel(byte WheelPos) {
  WheelPos = 255 - WheelPos;
  if(WheelPos < 85) {
    return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3,0);
  if(WheelPos < 170) {
    WheelPos -= 85;
    return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3,0);
  WheelPos -= 170;
  return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0,0);
uint8_t red(uint32_t c) {
  return (c >> 16);
uint8_t green(uint32_t c) {
  return (c >> 8);
uint8_t blue(uint32_t c) {
  return (c);
Here are some usefull ressources :
I suggest you to study the NeoPixels examples included on the Arduino Patch. They'll allow you to understand those two functions.
rainbowFade2White(x,x,x);
colorWipe(strip.Color(x, x, x), 50);
