This project is a fully functional mechanical clock driven by a single electric motor. The goal was to recreate a classic gear-based timekeeping mechanism, where the motor turns the seconds gear once per minute, and this movement is transmitted through a chain of wooden gears to control the minute and hour hands.
All gears were custom-designed in Fusion 360, respecting a strict constraint: no gear could have more than 60 teeth. This required careful calculation of gear ratios and multi-stage transmission to achieve:
1 rotation of the minute hand every 60 minutes
1 rotation of the hour hand every 12 hours
The gears were laser-cut from plywood, offering both mechanical precision and a clean, aesthetic look. The entire clock structure (gears, frame, and hands) was built by hand using digital fabrication tools.
An Arduino and a 28BYJ-48 stepper motor control the movement, turning the seconds gear at exactly 1 revolution per minute. No additional motors are used; all hands move through mechanical transmission alone.
This project combines:
Mechanical design
Digital fabrication
Electronics
Gear ratio optimization
Aesthetic woodworking
The result is a beautiful and accurate timepiece that showcases how precise and elegant mechanical systems can be even when made from simple materials like wood.
maxandre.lena
Steve
terryspitz
Joren Heit
