• Box
    luis.ramirez-ramirez04/22/2025 at 09:58 0 comments
  • 08/04/2025
    luis.ramirez-ramirez04/08/2025 at 10:19 0 comments
    Box will be made out of wood, prototype of carton
    finalisation of lazer cut for the box and platform
  • Mechanical constraints
    louis.duprey03/18/2025 at 09:32 0 comments
    While the cylinder itself will be exposed to very little stress, the gearing will face considerably more
    Due to expected stresses exerted upon the driving gear and those dedicated to the governor, it would seem they will need to be metallic or otherwise sturdier than a simple 3D printing
    For that reason, we will need to look at using standardized parts in order to simplify the building process
  • Governor related analysis
    louis.duprey03/18/2025 at 08:53 0 comments
    The purpose of the governor in the system is to ensure a stable speed of the cylinder
    It accomplishes this goal by increasing its rotational inertia the faster the device is turning
    It does so by having a pair of mobile counterweight that get higher and further from the axle as the rotation speed increase
    We will be using a version of the mechanism called the Watt Governor
    This version is fully passive, with no tuning component beyond the mass of the counterweights
    For our purpose, the ideal situation would be a rotation speed between 150 and 200 rpm with counterweight somewhere between 15 and 20 grams per counterweight
    The user is deemed to spin the handle between 60 and 120 rpm
    With the current gear shaft, this means the driving gear will go from 12 to 24 rpm
    In order to reach our operating rotational speed, we need to have a gear ratio in the neighborhood of 15 between the driving gear and the governor.
  • 11/03/24 : Progress log
    louis.duprey03/11/2025 at 11:13 0 comments
    Speed regulation of the system will be done using a governor.
    Found what kind of governor to use (Watt governor, fully gravity driven)
    Started to look at requirements for manufacturing
    Fine tuning will be done once prototype is assembled
    started model of worm gear and handle.
  • 04/03/2025
    luis.ramirez-ramirez03/04/2025 at 09:47 0 comments
    • Recived the kalimba. We worked with fusion 360°to upload the kalimba into the program then we measured the, angles, and size of the cylinder to fit the kalimba and the tines(notes).
  • 25/02 Progress log
    louis.duprey03/04/2025 at 09:35 0 comments
    Decision upon the actual project : making a music box
    Research of requirements for said project
    Identification of 4 main requirements for it : resonance chamber, metal prongs, cylinder, rotation mechanism
    The first two requirements are solved by using a kalimba as a base.
    Working on the other two
