Box
04/22/2025 at 09:58 • 0 comments -
08/04/2025
04/08/2025 at 10:19 • 0 commentsBox will be made out of wood, prototype of carton
finalisation of lazer cut for the box and platform
Mechanical constraints
03/18/2025 at 09:32 • 0 commentsWhile the cylinder itself will be exposed to very little stress, the gearing will face considerably more
Due to expected stresses exerted upon the driving gear and those dedicated to the governor, it would seem they will need to be metallic or otherwise sturdier than a simple 3D printing
For that reason, we will need to look at using standardized parts in order to simplify the building process
Governor related analysis
03/18/2025 at 08:53 • 0 commentsThe purpose of the governor in the system is to ensure a stable speed of the cylinder
It accomplishes this goal by increasing its rotational inertia the faster the device is turning
It does so by having a pair of mobile counterweight that get higher and further from the axle as the rotation speed increase
We will be using a version of the mechanism called the Watt Governor
This version is fully passive, with no tuning component beyond the mass of the counterweights
For our purpose, the ideal situation would be a rotation speed between 150 and 200 rpm with counterweight somewhere between 15 and 20 grams per counterweight
The user is deemed to spin the handle between 60 and 120 rpm
With the current gear shaft, this means the driving gear will go from 12 to 24 rpm
In order to reach our operating rotational speed, we need to have a gear ratio in the neighborhood of 15 between the driving gear and the governor.
11/03/24 : Progress log
03/11/2025 at 11:13 • 0 commentsSpeed regulation of the system will be done using a governor.
Found what kind of governor to use (Watt governor, fully gravity driven)
Started to look at requirements for manufacturing
Fine tuning will be done once prototype is assembled
started model of worm gear and handle.
04/03/2025
03/04/2025 at 09:47 • 0 commentsRecived the kalimba. We worked with fusion 360°to upload the kalimba into the program then we measured the, angles, and size of the cylinder to fit the kalimba and the tines(notes).
25/02 Progress log
03/04/2025 at 09:35 • 0 commentsDecision upon the actual project : making a music box
Research of requirements for said project
Identification of 4 main requirements for it : resonance chamber, metal prongs, cylinder, rotation mechanism
The first two requirements are solved by using a kalimba as a base.
Working on the other two
