Apagado de RPI/Pantallas al salir de Retrobat
A project log for THE ULTIMATE MINI ARCADE
Classic arcade with all the latest technological advancements, ready for the classics. Enjoy!
srrubioSrRubio 09/20/2025 at 16:060 Comments
1️⃣ Configuración en Windows
  1. Instalar Ncat
    • Instala Nmap para usar ncat.
    • Ruta recomendada: C:\Program Files (x86)\Nmap\ncat.exe.
    • Comprobar que desde CMD puedes ejecutar:
      "C:\Program Files (x86)\Nmap\ncat.exe" --version
  2. Scripts de Windows
    1.1. start.bat
    • Gestiona cierre de procesos, lanzamiento de RetroBat y monitor, y envía SHUTDOWN al cerrar.
    • Contenido ya funcional que compartiste:
    @echo off
    setlocal enabledelayedexpansion
    set "MONITOR_BAT=C:\RetroBat\plugins\MarqueeManager\marquee_monitor.bat"
    set "MONITOR_TITLE=RetroBat_MarqueeMonitor"
    set "NCAT_EXE=C:\Program Files (x86)\Nmap\ncat.exe"
    set "RPI_IPS=192.168.1.138 192.168.1.145"
    set "RPI_PORT=12345"
    cd /d "%~dp0"
    :: --- Cerrar procesos previos ---
    for %%P in (  ESEvents.exe  ESEventsScrapTopper.exe  ESRetroAchievements.exe  VPListenerWS.exe  MAMEListenerWS.exe  SUPERMODELListenerWS.exe  retroarch.exe  mpv.exe  dmd.exe  emulationstation.exe
    ) do (  tasklist | find /I "%%P" > NUL && taskkill /IM %%P /F
    :: --- Limpiar tmp del MarqueeManager ---
    rd /s /q ".\.tmp" 2>NUL
    :: --- Iniciar monitor ---
    start "%MONITOR_TITLE%" cmd /k ""%MONITOR_BAT%""
    :: --- Iniciar ESEvents ---
    start "" ESEvents.exe
    timeout /t 1 /nobreak >NUL
    :: --- Iniciar RetroBat ---
    start "" ..\..\retrobat.exe
    timeout /t 2 /nobreak >NUL
    :: --- Esperar a que RetroBat termine ---
    :wait_rb
    tasklist | find /I "retrobat.exe" >NUL
    if not errorlevel 1 (    timeout /t 2 >NUL    goto wait_rb
    tasklist | find /I "emulationstation.exe" >NUL
    :: --- Cerrar monitor ---
    taskkill /FI "WINDOWTITLE eq %MONITOR_TITLE%" /F
    :: --- Enviar SHUTDOWN a RPis ---
    for %%I in (%RPI_IPS%) do (    echo [%time%] Enviando SHUTDOWN a %%I:%RPI_PORT%...    echo SHUTDOWN | "%NCAT_EXE%" %%I %RPI_PORT% -w 1
    endlocal
    1.2. marquee_monitor.bat
    • Recibe eventos de RetroBat (sistema y ROM) y los envía a las RPis.
    • Contenido funcional que compartiste: no hay cambios, se mantiene tal cual.
2️⃣ Configuración en la RPi
  1. Script mostrar_rom_ipc.sh
    • Permisos:
      sudo chmod +x /usr/local/bin/mostrar_rom_ipc.sh
    • Contenido funcional que compartiste: mantener tal cual.
  2. Servicio systemd
    • Crear archivo: /etc/systemd/system/marquee-mpv.service
    [Unit]
    Description=Marquee MPV IPC Listener
    After=network.target
    [Service]
    Type=simple
    User=arcade
    ExecStart=/usr/local/bin/mostrar_rom_ipc.sh
    Restart=always
    RestartSec=2
    StandardOutput=syslog
    StandardError=syslog
    SyslogIdentifier=marquee-mpv
    [Install]
    WantedBy=multi-user.target
    • Ajusta User=arcade si tu usuario es diferente.
  3. Habilitar y arrancar el servicio
    sudo systemctl daemon-reload
    sudo systemctl enable marquee-mpv.service
    sudo systemctl start marquee-mpv.service
    • Comprobar estado:
    sudo systemctl status marquee-mpv.service
    • Esto asegura que siempre se levante al iniciar la RPi y esté escuchando los mensajes de Windows.
3️⃣ Pruebas
  1. Desde Windows, prueba el envío manual:
    echo SHUTDOWN | "C:\Program Files (x86)\Nmap\ncat.exe" 192.168.1.138 12345 -w 1
    • La RPi debería apagarse.
  2. Lanzar start.bat en Windows:
    • RetroBat se inicia.
    • Monitor registra los eventos de sistema/ROM y los envía a las RPis.
    • Al cerrar RetroBat, el monitor envía SHUTDOWN automáticamente.
  3. Revisar logs:
    • Windows: C:\temp\marquee_debug.log
    • RPi: /home/arcade/mostrar_rom_debug.log
