Beefing up the amplifier!
A project log for Protomatrix
First breadboard with a matrix router
vlad-shcherbakovVlad Shcherbakov 12/08/2025 at 03:110 Comments
I beefed up the amplifier I built couple months ago for this article. I was not satisfied with the tiny sound so I bough a PNP/NPN pair BD679/BD680, high-voltage op-amp LF412CN/NOPB, and a nice jack from Sparkfan. Results you can see... and hear!
The extra op-amp is for mixing left and right channels.
I had to bypass one high-current track with a wire instead of using the matrix (not visible, not the black wire), but the rest worked. Also, by-pass capacitors are absolute MUST when so much inductance is present in the tracks.
Links
Engine sounds from THOR
