Key Features:
Microcontroller Support: Atmega328P-PU
Bootloader Installation: Arduino Uno bootloader (5V, 16 MHz)
Interface: USB-C 5V power supply
User Interface: LEDs and buzzer for success/failure notification
Microcontroller State: Supports programming blank or previously used microcontrollers
Speed: Programming takes only about 7 seconds
Benefits:
Standalone Operation: No computer or additional Arduino board required for programming.
Simplified Workflow: Streamlined bootloader installation process.
Wide Compatibility: Works with blank or previously used microcontrollers.
Visual Feedback: LEDs and buzzer provide clear status indication.
Applications:
Programming Atmega328P microcontrollers for custom projects.
Restoring or replacing bootloaders on malfunctioning devices.
Educational and prototyping environments for learning AVR microcontroller programming.
Additional Notes:
Pre-assembled and tested for immediate use.
