Breadboard Power Supply 3.3V, 5V, 12V and USB UART
PSU module for standard breadboards with switching regulators and integrated CH340 USB UART bridge.
Public Chat
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Starting from
has orders / reviews
Ships from
- Input voltage 5V, 2.1A from standard USB charger. - >90% high-efficiency DC-DC switching converters. - Output voltage 5V, 2A (max.), electronically protected - Output voltage 3.3V, 2A (max.), electronically protected - Output voltage 12V, 0.5A (max.), electronically protected - USB Type-C port for power supply and serial communication. - CH340K USB-UART for programming and serial communication. - Selectable RX/TX logic level (3.3/5V) and 50bps to 2Mbps transfer speed - Reset signal output for easy programming of microcontrollers.
