Arduino SPWM inverter
A simple Arduino SPWM inverter shield
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
For a recent project course, I built an SPWM Arduino inverter to levitate an aluminum ring around an iron rod using electromagnetic induction. The goal: convert DC into AC to drive a coil, inducing a repulsive field in the ring to make it levitate.
It uses SPWM to drive 2 IR2101 which drives a H-bridge.
JLCPCB (https://jlcpcb.com/?from=see) was used for manufacturing the PCB.
