Little troubles for the graph...
A project log for P.A.M.
Pollution Air Monitoring
pamPAM 06/01/2017 at 08:170 Comments
Here, you can take a look at our final platform design.
It should help to understand the data easily. You just need then to open google maps on another window to check where you've been.
Unfortunately, we had some troubles to draw the graph with the processing code. We are still working on it.
