Little by little
A project log for dual-mode 16-segments LED display module
A project I develop with the kids for H1 2017 at CercleJ.
yann-guidon-ygdesYann Guidon / YGDES 03/16/2017 at 03:450 Comments
Small steps...
The system is getting better defined, a we're trying to make an all-circuit controller.
We're also building a final prototype with the definitive parts, and the new LEDs are superior to the old we used before, as they "sit" directly on the PCB and require much less adjustments of position.
That means : a lot of time will be saved when 4200 of them will be manually assembled !
