The main body is laser cut 3.4mm plywood stained dark with a coat of spray matte poly finish.
The speaker grill is some random fabric also laser cut to shape.
The diffuser for the LED is 3D printed in a matte gold PLA.
The 3.2 VDC LED leads are soldered directed to the 2 pin header.
It's all held together and insulated with low temp hot snot glue.
That's it.
See latest project update for prototype BT speaker version!
jeremy.geppert
Hulk
Markus Loeffler
yan
555Techlab
