Axis 1
05/21/2025 at 14:37 • 0 commentsLet's start from the beginning. Axis 1. The servo is attached to the base with m4 bolts. The cover is bolted M6. It looks reliable. Two bearings are used to reduce backlash. The motor housing of the second axle is fixed through the flange. The rotor-flange connection is collapsible.
