Wheelchair Sensor for Buses
Something to help Wheelchair users ride the bus.
Public Chat
This project is that we are making a sensor that can detect a wheelchair. Upon detection, the app will be notified and show how many wheelchair seats are available or unavailable on the bus.
This model will be used to fit an Olympia City Bus. It will detect when the hook needed to secure the wheelchair is gone. Then after that point it will tell the app allowing others to see this.
WheelchairSensor (2).aia
Here is the file to access our app. This works with MIT App Inventor and import it to use it. It should connect to our code allowing you to see how many seats are available by connecting to the magnetic sensor on our prototype.
aia - 3.61 kB - 05/05/2025 at 17:17
Download
  • Model
    Essence of Carnage05/06/2025 at 17:06 0 comments
    Here is a picture of our model. We built it out of wood and it shows how the bus seat would be used.
  • April 30th Project Update
    Essence of Carnage04/30/2025 at 17:05 0 comments
    Update on our project! Right now we have all the code written and will post it shortly. Today our teacher got us access to a bus and we were able to view it. We now know where we are going to place our sensor and pictures will also be posted regarding that.
    Thank you for following our project and any feedback, questions, or help is very much appreciated.
    -Essence of Carnage
  • Prototype
    Essence of Carnage04/22/2025 at 17:41 0 comments
    Here is our prototype right now with our code. We will print our model of the bus seat and show pictures of it shortly.
  • Update from April 14-18th
    Essence of Carnage04/21/2025 at 17:12 0 comments
    Right now we have a lot of the bases of the code working. Recently, we have been working on Tinkercad and making a 3D printed design model to show to others. We are also working on the app via MIT app inventor.
    If anyone has any ideas or can help us in anyway we would be open to that.
  • Sensor Chosen
    Essence of Carnage04/10/2025 at 17:07 0 comments
    Hello Followers,
    Just wanted to let everyone know we have chosen a pressure sensor as our sensor! We will connect it to the I2C on our Adafruit. If anyone can offer any suggestions or feedback, we would love that.
    -Essence of Carnage
View all 5 project logs
  • 1
    Code
    Here is the code that works with our Adafruit and connects with the app which is linked in project files.
    #include <WiFi.h>
    #include <HTTPClient.h>
    const char* ssid = "WIFI_NETWORK";
    const char* password = "";
    // Domain Name with full URL Path for HTTP POST Request
    const char* serverName = "http://api.thingspeak.com/update";
    // Service API Key
    String apiKey = "THE_API_KEY";
    unsigned long lastTime = 0;
    // Timer set to 15 seconds (15000)
    unsigned long timerDelay = 15000;
    // State of the sensor
    int state = 0;
    void setup() {
      Serial.begin(115200);
      pinMode(13, INPUT_PULLUP);
      WiFi.begin(ssid, password);
      Serial.println("Connecting");
      while(WiFi.status() != WL_CONNECTED) {
        delay(500);
        Serial.print(".");
      Serial.println("");
      Serial.print("Connected to WiFi network with IP Address: ");
      Serial.println(WiFi.localIP());
      Serial.println("Timer set to 15 seconds (timerDelay variable), it will take 15 seconds before publishing the first reading.");
    void loop() {
      //Send an HTTP POST request every 15 seconds
      if ((millis() - lastTime) > timerDelay) {
        //Check WiFi connection status
        if(WiFi.status()== WL_CONNECTED){
          WiFiClient client;
          HTTPClient http;
          // Domain name with URL path or IP address with path
          http.begin(client, serverName);
          // Specify content-type header
          http.addHeader("Content-Type", "application/x-www-form-urlencoded");
          // Data to send with HTTP POST
          state = digitalRead(13);
          // Change the "&field1" to POST to other fields
          String httpRequestData = "api_key=" + apiKey + "&field1=" + String(state);
          // Send HTTP POST request
          int httpResponseCode = http.POST(httpRequestData);
          // If you need an HTTP request with a content type: application/json, use the following:
          http.addHeader("Content-Type", "application/json");
          // JSON data to send with HTTP POST
          String httpRequestData = "{\"api_key\":\"" + apiKey + "\",\"field1\":\"" + String(random(40)) + "\"}";
          int httpResponseCode = http.POST(httpRequestData);*/
          Serial.print("HTTP Response code: ");
          Serial.println(httpResponseCode);
          // Free resources
          http.end();
        else {
          Serial.println("WiFi Disconnected");
        lastTime = millis();
  • 2
    Wiring
    Each FeatherV2 needs a hall effect sensor plugged into GND and 3.3v, as well as the data pin plugged into digital pin 13.
View all instructions
