In the software, the required keystrokes can be defined per key. For instance:
press = 1; // Function
set("int () { // ~");
set(" ;~");
set(" return 0; ~");
set("}; // func~^^^<<<<<<<<"); Will result in the following code:
int () { //
return 0;
}; // func
And the cursor is placed between the brackets (). The following special characters are used:
< left arrow,
^ top arrow,
> right arrow,
# delete,
~ enter
Please keep in mind:
- Use the Adrduino Leonardo for programming, not the Pro!
- Unplug the Arduino pro and replug when compiling has started
- Or attach a reset button and press the reset button while compiling and release this button when "Waiting for upload port..." is shown.
- Connect pin A3 to ground, to cancel all keyboard presses (emergency stop).
- Macro Pad is ready for use when blue light is off.
Libraries used:
The input: https://playground.arduino.cc/Code/Keypad/
The output: https://docs.arduino.cc/language-reference/en/functions/usb/Keyboard/
Jeroen Brinkman
r57zone
Ithasu
