Fabrication
Laser cutting: All wooden parts (box, base, support) were cut using a laser cutter.
Servo mounting: The servomotors were screwed onto the base and mechanically connected to the racks.
Arduino box: We designed a closed wooden box (assembled without glue) to house the Arduino.
Wiring: The servos are connected to the Arduino through wires passing through a hole in
