Sandbox Animation
My project is to design a rotating neopixel matrix that mimics a rotating box of sand (using RGBW).
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
I will use an adafruit circuit playground with an accelerometer to determine the angle of the matrix which will determine which image is put on the screen. And a stepper motor to create the rotation. I found that creating a good sand color on the neopixels could be done with (175,0,0,50) with 50 white being the biggest factor.
