When you open the project manager, you can now "Delete" items from the UI. It will not actually delete anything, but rather writes an ignore file in the projects directory. At some point in the future i intend to have some sort of un-delete interface, but for now just removing the ignore file by hand is a reasonable un-delete method.
Kevin Harrington
