The author: WildboarG
Materials
Rd-04
Notification Push
This project uses Gotify, which requires setting up a server. For details, refer to AI-WB2 Notification Push to Personal Devices.
Enable Notifications
A simple HTTP server has been set up with a static toggle switch to control notifications, preventing frequent triggers and making the system more user-friendly.
Disable the sentry to stop notifications.
Enable it to resume normal notification pushes to the mobile client.
Code Example
Repository: https://github.com/WildboarG/Picket.git
Main Thread
void rd_task(void *pvParameters) {
  // Construct message content structure
  static const char title[] = "RD04";
  static const char message[] = "Trigger the radar notification";
  static const char priority[] = "0";
  static Message msg = {title, message, priority};
  printf("title=%s \r\nmessage=%s\r\npriority=%s\r\n", msg.title, msg.message,
         msg.priority);
  while (1) {
    // Continuously monitor RD output
    hosal_gpio_input_get(&show, status);
    vTaskDelay(3000);
    // Trigger notification
    if (status[0]) {
      // Push message to mobile
      xTaskCreate(¬ify_task, "notify_task", 1024 * 10, &msg, 5, NULL);
Radar Driver
#include "FreeRTOS.h"
#include "hosal_i2c.h"
#include "task.h"
#include <rd04.h>
#include <stdint.h>
#include <stdio.h>
#define RD_ADDR 0x71
extern hosal_i2c_dev_t i2c0;
void IIC_WriteData(uint8_t reg_addr, uint8_t Buff) {
  uint8_t Data[2];
  uint8_t ret = -1;
  Data[0] = reg_addr;
  Data[1] = Buff;
  ret = hosal_i2c_master_send(&i2c0, RD_ADDR, Data, sizeof(Data),
                              HOSAL_WAIT_FOREVER);
  if (ret != 0) {
    printf("err:%c\n", Buff);
uint8_t IIC_ReadData(uint8_t reg_addr) {
  uint8_t read_data[1];
  read_data[0] = reg_addr;
  hosal_i2c_master_recv(&i2c0, RD_ADDR, read_data, 1, HOSAL_WAIT_FOREVER);
  return read_data;
void RD_04_Init(void) {
  printf("Initializing radar\r\n");
  uint8_t value;
  for (uint8_t i = 0; i < 5; i++) {
    IIC_WriteData(0x13, 0x9B);
    vTaskDelay(1);
    value = IIC_ReadData(0x13);
    printf("READ VALUE =0x%02X\r\n", value);
  IIC_WriteData(0x24, 0x03);
  IIC_WriteData(0x04, 0x20);
  IIC_WriteData(0x10, 0x20);
  IIC_WriteData(0x03, 0x40);
  IIC_WriteData(0x1C, 0x21);
  IIC_WriteData(0x18, 0x6a);
  IIC_WriteData(0x19, 0x00);
  IIC_WriteData(0x1A, 0x55);
  IIC_WriteData(0x1B, 0x01);
  IIC_WriteData(0x1D, 0x80);
  IIC_WriteData(0x1E, 0x0C);
  IIC_WriteData(0x1F, 0x00);
  IIC_WriteData(0x20, 0x00);
  IIC_WriteData(0x21, 0x7D);
  IIC_WriteData(0x22, 0x00);
  IIC_WriteData(0x23, 0x0C);
  vTaskDelay(3000);
  printf("Radar initialization successful\r\n");
Notification Task
void notify_task(void *pvParameters) {
  Message *params = (Message *)pvParameters; // Receive parameters
  printf("title=%s \r\nmessage=%s\r\npriority=%s\r\n", params->title,
         params->message, params->priority);
  const struct addrinfo hints = {
      .ai_family = AF_INET,
      .ai_socktype = SOCK_STREAM,
  struct addrinfo *res;
  struct in_addr *addr;
  int s, r;
  char recv_buf[4096];
  while (1) {
    int err = getaddrinfo(WEB_SERVER, WEB_PORT, &hints, &res);
    if (err != 0 || res == NULL) {
      blog_error("DNS lookup failed err=%d res=%p", err, res);
      vTaskDelay(1000 / portTICK_PERIOD_MS);
      continue;
    addr = &((struct sockaddr_in *)res->ai_addr)->sin_addr;
    blog_info("DNS lookup succeeded. IP=%s", inet_ntoa(*addr));
    s = socket(res->ai_family, res->ai_socktype, 0);
    if (s < 0) {
      blog_error("... Failed to allocate socket.");
      freeaddrinfo(res);
      continue;
    blog_info("... allocated socket");
    if (connect(s, res->ai_addr, res->ai_addrlen) != 0) {
      blog_error("... socket connect failed errno=%d", errno);
      close(s);
      freeaddrinfo(res);
      vTaskDelay(4000 / portTICK_PERIOD_MS);
      continue;
    blog_info("... connected");
    freeaddrinfo(res);
    // Construct request body
    char body[1024];
    snprintf(body, sizeof(body),
             "--%s\r\n"
             "Content-Disposition: form-data; name=\"title\"\r\n\r\n"
             "%s\r\n"
             "--%s\r\n"
             "Content-Disposition: form-data; name=\"message\"\r\n\r\n"
             "%s\r\n"
             "--%s\r\n"
             "Content-Disposition: form-data; name=\"priority\"\r\n\r\n"
             "%s\r\n"
             "--%s--\r\n",
             BOUNDARY, params->title, BOUNDARY, params->message, BOUNDARY,
             params->priority, BOUNDARY);
    snprintf(REQUEST, sizeof(REQUEST),
             "POST %s%s HTTP/1.0\r\n"
             "Host: %s:%s\r\n"
             "User-Agent: aithinker wb2\r\n"
             "Content-Type: multipart/form-data; boundary=%s\r\n"
             "Content-Length: %d\r\n"
             "\r\n"
             "%s",
             WEB_PATH_BASE, QUERY_STRING, WEB_SERVER, WEB_PORT, BOUNDARY,
             strlen(body), body);
    printf(REQUEST);
    if (write(s, REQUEST, strlen(REQUEST)) < 0) {
      blog_error("... socket send failed");
      close(s);
      continue;
    blog_info("... socket send success");
    struct timeval receiving_timeout;
    receiving_timeout.tv_sec = 5;
    receiving_timeout.tv_usec = 0;
    if (setsockopt(s, SOL_SOCKET, SO_RCVTIMEO, &receiving_timeout,
                   sizeof(receiving_timeout)) < 0) {
      blog_error("... failed to set socket receiving timeout");
      close(s);
      continue;
    blog_info("... set socket receiving timeout success");
    extern int bl_putchar(int c);
    /* Read HTTP response */
    do {
      bzero(recv_buf, sizeof(recv_buf));
      r = read(s, recv_buf, sizeof(recv_buf) - 1);
      for (int i = 0; i < r; i++) {
        bl_putchar(recv_buf[i]);
    } while (r > 0);
    blog_info("... done reading from socket. Last read return=%d "
              "errno=%d\r\n",
              r, errno);
    close(s);
    for (int countdown = 10; countdown >= 0; countdown--) {
      blog_info("%d... ", countdown);
    blog_info("Starting again!");
    vTaskDelete(NULL);
