Test Bed
A project log for Tortuga - A sand drawing robot
Inspired by the likes of Disney Research and Ivan Miranda, I have decided to make a small scale sand drawing robot.
r-langR Lang 04/09/2025 at 13:070 Comments
Although this doesn't represent the finalised design, this is generally the direction I've chosen to go. The idea of this will be to test the ability of Tortuga to drive on sand and to test out a number of things:
A. Ingress of sand into the electronics
B. If low pressure, slick tyres will adhere enough on sand
C. How accurately can Tortuga steer in such a small form factor.
My initial thoughts are the front wheel will need more room to manoeuvre - maybe a castor based wheel, if not, depending on the level of difficulty in implementing, regenerative steering/differential steering - the same thing that allows tanks to perform "neutral turns" (tank donuts).
