Test bed V1.
A project log for Tortuga - A sand drawing robot
Inspired by the likes of Disney Research and Ivan Miranda, I have decided to make a small scale sand drawing robot.
r-langR Lang 08/30/2025 at 17:070 Comments
So here is an initial assembly idea of what the test bed will look like. The front bay will be for seating a battery, the finished test shell would likely have venting for batteries, maybe some kind of hexagonal pattern at the bottom. The idea of keeping it as sealed as possible is to prevent sand ingress into the motors and electronics.
The rear component is a hinge design to actuate the tail, Tortuga when wanting to carve into the sand will actuate its tail downwards at a set angle and drag it behind it, producing the desired line. Not shown:
Servo to actuate the tail
Nose wheel steering servo
Batteries
ESP32 or Raspberry Pi 0w
