The Rd-60 is a low-power radar module developed by Ai-Thinker, featuring an integrated 60GHz FMCW carrier AiP mmWave radar system and multi-protocol wireless connectivity, including BLE5.3/802.15.4/Thread/Matter.
The module includes a 1T3R AiP radar antenna array, a 2.4GHz transceiver antenna, crystal, and Flash.
It features four low-power management modes: power-off, standby, idle, and working. Configuration and data acquisition are achieved through digital interfaces such as UART(SPI/I²C).
Product Features of Rd-60
- SMD packaging compatible with 1.27mm pin headers
- Radar spectrum ranges from 58GHz to 64GHz, with a continuous sweep bandwidth of 6GHz
- Radar antenna supports 1T3R, enabling configurations of 1T1R, 1T2R, and 1T3R
- Equivalent isotropic radiated power (EIRP) of 17.5dBm
- Wide radar detection angle with a horizontal FOV of 120 degrees and a vertical FOV of 120 degrees
- Maximum detection range of 8 meters (depending on the target's RCS size)
- Minimum detection range of 0.01 meters (referenced to a human target)
- Module dimensions: 22.5*18.5mm
- Supported protocols: Physical layer supports BLE 5 and 802.15.4; protocol layer supports BLE 5.3
- Bluetooth LE PHY: 1Mbps, 2Mbps, long-range S2 (500Kbps), S8 (125Kbps)
The Rd-61 is a low-power 60GHz FMCW carrier AiP radar module developed by Ai-Thinker. The module integrates a 1T3R AiP radar chip and Flash.
The module features four low-power management modes: power-off, standby, idle, and working. Configuration and data acquisition are achieved through the UART interface.
Product Features
- Minimum detection range of 0.01 meters (referenced to a human target)Ultra-compact module dimensions: 18.5*6.5mm
Highlights
Ultra-Low Power Consumption
The Ai-Thinker 60GHz mmWave radar modules feature four low-power management modes: power-off, standby, idle, and working. Actual test results show:
Rd-60: As low as 77.82μA when no one is present, and 1.67mA when someone is present.
Rd-61: As low as 56.25μA when no one is present, and 1.67mA when someone is present.
The modules can detect various human states within a region in low-power mode and can be applied to products such as door locks and doorbells.
Small Size, Plug-and-Play
The compact size saves product space and can be quickly embedded into the main product board. Plug-and-play functionality allows flexible application in various smart scenarios and terminal products. (Choose Rd-60 for Bluetooth needs; choose Rd-61 for a smaller size)
Excellent Anti-Interference Capability and Stable Performance
The modules offer superior detection capabilities, a simplified development process, and multi-protocol wireless connectivity. The patented AiP mmWave antenna technology achieves industry-leading levels in bandwidth, gain, and FOV performance, addressing pain points in the smart sensor industry such as unstable performance, insufficient detection capabilities, and complex development processes.
No Coding Required
UART Commands for Instant Parameter Adjustment
Shell Control Mode:
Send corresponding shell commands via serial port to configure radar sensitivity, detection mode, and reporting frequency.
Point Cloud and 1D/2DFFT Data Output:
Raw data on human movement distance, trajectory, speed, and breathing/heart rate can be obtained with one click for analysis, shortening the development cycle.
Application Scenarios
Support for Point Cloud Data and Multi-Dimensional Perception
· Output...
Ai-Thinker
Raphael Valceschini
