DIY Modular Water Purifier – Open-Source, Solar-Ready, and Scalable
Project: KidneyLoop
"Not a company. Just a citizen trying to help."
Hi Hackaday!
This is a personal DIY project I’ve been working on called KidneyLoop — an open-source, modular water purification system that runs off small solar panels, rain barrels, and basic pumps. It uses micron filtration + UV-C light to cycle dirty water through multiple sanitation loops until it's clean.
It’s based on the principle of how kidneys work: loop it, clean it, return it.
🌍 Why I Built This
Millions of people worldwide — including folks in places like Flint, Michigan — still don’t have access to clean water.
Most solutions are expensive, plastic-heavy, or not portable.
I wanted to create a simple, scalable, low-power sanitation loop using parts you can order on Amazon or get locally.
The design is modular and can be scaled up from a couple buckets to full 1000-gallon rain tanks.
This is not a business. This is a community-licensed CC0 (public domain) project, released for anyone to build, improve, or even sell.
⚙️ How It Works (At a Glance)
Water leaves the dirty tank.
Goes through a micron filter to remove debris.
Flows through a UV-C sterilizer to kill pathogens.
Through another micron filter for polishing.
Into the clean tank.
A second pump routes the clean water back to the dirty tank, completing the loop.
Repeat 3–6 cycles. The water gets cleaner each time. Add a carbon filter to also remove chlorine and fluoride for tap water use.
🔧 Parts Used (Real-World, Amazon-Friendly)
2x 55–1000 gal rain barrels or water tanks
2x 12V micro water pumps (~$12 for a 2-pack)
12W inline UV-C sterilizer (~$60)
1/4” food-grade tubing (10–30 ft)
Micron filters (before and after UV-C)
Solar panel (20W or higher) OR AC power
(Optional) 12V battery, carbon filter, tubing clamps
🧪 I’ll upload real pics of the components and actual white papers. This is untested, but based on known principles and safe materials.
💡 What This Is
✅ CC0-licensed
✅ DIY + open-source
✅ Modular (can be scaled)
✅ Designed for water-stressed regions
✅ Fully solar-operable
✅ Does not require plumbing or grid hookup
✅ Can sanitize tap, rain, or stream water
🔍 What This Is Not
⚠️ Not yet tested for WHO/EPA certification
⚠️ Not a product — no sales, no marketing
⚠️ Not a one-size-fits-all solution — it's a framework
📂 GitHub Repository
Includes white papers, parts lists, diagrams, and real photos:
🔗 https://github.com/Polymath8/KidneyLoop-Water-Filtration
You’ll find:
💧 The Flint, Michigan white paper (removes metals via carbon filtration)
🛠️ The modular system paper with build steps
🙏 Let’s Build This Together
If you're into DIY, survival setups, off-grid sanitation, or just care about clean water — I’d love your feedback or ideas. This isn’t perfect, but I wanted to get it out there and evolve it together.
Let’s build this into something that could help people anywhere.
— Polymath
Polymath8
tlankford01
Paul Scott
Anteneh Gashaw
