Emergency Bus Button
A button in a bus that notifies the driver if you feel unsafe or possibly in danger.
Public Chat
This button could be used in all buses. All you have to do is press it when you feel unsafe or in danger and it will immediatly notify the driver. Through an LCD screen and it would say which seat pushed the button so the bus driver could check on the person and remove them from a dangerous situation.
Portable Network Graphics (PNG) - 333.74 kB - 05/02/2025 at 17:15
Preview
Portable Network Graphics (PNG) - 578.62 kB - 04/30/2025 at 17:41
Preview
Portable Network Graphics (PNG) - 631.75 kB - 04/30/2025 at 17:40
Preview
Portable Network Graphics (PNG) - 682.49 kB - 04/30/2025 at 17:40
Preview
Portable Network Graphics (PNG) - 664.52 kB - 04/30/2025 at 17:39
Preview
View all 9 files
  • 1 × LCD Screen
  • 1 × Mega Arduino Board
  • 30 × Wires Could have Extra wires
  • 1 × Magnet
  • 1 × Hall Effect Sensor
View all 7 components
  • Final Week
    Trevor Anderson05/05/2025 at 17:48 0 comments
    We revised and fixed some problems in the project and we made sure the project is ready to turn in and send out to the world.
  • Real Bus
    Trevor Anderson05/02/2025 at 17:09 0 comments
    We took pictures of places we could put the button on a real bus for planning. This helped us understand more on how we are going to execute this plan.
  • Week 4 (Hall Effect Sensor)
    Trevor Anderson04/21/2025 at 17:14 0 comments
    We wired and coded the hall effect Sensor to notify a screen when a button is pressed. The button will notify the driver of the bus saying "Seat _ needs help" depending on what button at which seat is pressed.
  • Week 3 (Coding)
    Trevor Anderson04/14/2025 at 17:49 0 comments
    We are now working on the coding in Arduino. We have been able to complete the coding for the prototype using Arduino and the buttons on the LCD screen
  • Week 2 (LCD Board with wires)
    Trevor Anderson04/14/2025 at 17:39 0 comments
    We finished researching and started wiring up and building our model. So now we are just talking about wired. We got stuck on how to wire the parts togeher for a couple days but then we figured it out and finshed wiring the parts together.
  • Week 1 (LCD Board no wires)
    Trevor Anderson04/14/2025 at 17:34 0 comments
    We did research and put our minds/ideas together to figure out how we going to make the Emergency button a reality to help those who need it most. Then we reasearched what parts we were gonna need, how to wire the parts, and how to code it all.
View all 6 project logs
  • 1
    Code for Project
    int sensorPin = 30;
    int counter = 0;
    #include <LiquidCrystal_I2C.h>
    #include  <Wire.h>
    const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
    LiquidCrystal_I2C lcd(0x27,  16, 2);
    void setup()
      // setup serial - diagnostics - port
      Serial.begin(9600);
      pinMode(sensorPin, INPUT_PULLUP);
      lcd.begin(16,2);
       //initialize lcd screen
      lcd.init();
      // turn on the backlight
      lcd.backlight();
    void loop()
      counter++;
      int sensorValue = digitalRead(sensorPin);
      Serial.print(counter);
      Serial.print(" ");
      Serial.println(sensorValue);
      delay(250);
      if(sensorValue == 0){
        lcd.setCursor(0,1);
        lcd.print("seat 1 needs help");
        delay(5000);
        lcd.setCursor(0,1);
        lcd.print("                        ");
  • 2
    Connecting Wires
    3.3v or 5v on Mega Arduino Board to VCC on LCD Screen
    GND on Mega Arduino Board to GND on LCD Screen
    SCL on Mega Arduino Board to SCL on LCD Screen
    SDA on Mega Arduino Board to SDA on LCD Screen
  • 3
    Hall Effect Sensor Wiring
    Hall Effect Sensor GND to Mega Arduino Board GND
    Hall Effect Sensor +VCC to Mega Arduino Board 5V
    Hall Effect Sensor Output to any digital pin on Mega Arduino Board (Use pin 30 if you don't want to have to change the code)
    Put Resistor through output pin and 5V pin (10k Resistor)
View all 3 instructions
