The Microtronic Phoenix Computer System - A Microtronic Emulator Running the Original Firmware from 1981
Jason T. Jacques: TMS1xxx emulator, prototype hardware design and breadboarding, refined Microtronic firmware dumping, authentic Microtronic firmware emulator running the original Microtronic firmware ROM with a TMS1600 emulator
Decle: TMS1xxx firmware ROM dumping technology, TMS1xxx disassembler, expert technical advisor
Michael A. Wessel: Arduino-based re-implementation of the Microtronic, first round of Microtronic firmware dumping, PCB design, software integration
About
The Microtronic Phoenix represents a quantum leap in Microtronic emulation.
The Microtronic was an educational 4bit single-board computer system, which was released in 1981 by the company Busch Modellbau in West Germany:
Unlike previous hardware emulators of the 1981 Busch 2090 Microtronic Computer System, the Phoenix emulator is the first emulator that is not only a re-implementation of the Microtronic, but actually runs the original TMS1600 firmware from 1981.
This breakthrough was made possible by a collaboration of Decle, Jason T. Jacques and Michael Wessel, referred to as "the team" in the following.
This project is shared with the community to enable others to relive and experience the original 1981 Busch Microtronic Computer System in an as-authentic-as-possible way.
Latest News
04-12-2025: All Firmware variants uploaded ("Phoenix", "Neo Only", "Phoenix Only").
02-22-2025: "Neo Only" firmware uploaded.
Background & Genesis
The Microtronic is powered by a mask-programmed Texas Instruments 4bit microcontroller, the TMS1600.
Until now, an authentic Microtronic emulator was impossible as the official firmware had been lost to history, and there was no documented procedure for reading out ("dumping") a TMS1600 firmware ROM. Firmware ROMs of related TMS1xxx devices (e.g., the SIMON game, TI calculators, and the Science Fair Microcomputer Trainer) had been retrieved in the past, but the process usually involved destructive die-decapping.
More recently, an alternative to destructive chip decapping was discovered for dumping the ROM of the 1985 Radio Shack Science Fair Microcomputer Trainer. This process utilizes an Arduino for putting the TMS1xxx into the so-called test mode, which then allows download of the firmware ROM over a serial interface.
After a lot of trial-and-error, the team finally succeeded in April 2024 in retrieving the Microtronic firmware ROM, hence opening up the avenue of re-creating the original Microtronic on modern hardware. The process is described here and, much more detailed and technically accurate, here.
After Decle and Michael had succeeded in enabling the TMS1600 test mode (this process was nowhere documented on the Internet back then), and succeeded in downloading a first version of the Microtronic ROM, Jason then took the lead and analyzed and double checked it, corrected some errors by hand (despite all our efforts, the retrieved firmware still contained some ambiguity!), and, for the first time in history, created an ATmega-based breadboard Microtronic running the original firmware on his TMS1xxx emulator!
Jason's work of curating the firmware and his TMS1xxx Microtronic breadboard hardware emulator opened the avenue of recreating a retro-authentic new version of the Microtronic on modern hardware, running the original 1981 firmware ROM on a TMS1600 emulator on an Arduino / ATmega. We are hence calling this new Microtronic hardware emulator the Phoenix.
Phoenix Overview
The Phoenix board uses an ATmega 644P-20U clocked at 20 MHz, a 24LC256 EEPROM, and an 74LS244 in an abundance of pre-caution for connecting the ATmega's GPIOs to the external world of Microtronic INPUT / OUTPUT ports.
The three different Phoenix firmwares are provided as Arduino folders / "sketches". See below for descriptions of these three different variants. The Arduino Legacy IDE IDE 1.8.19 in combination with MightyCore are used for firmware compilation and uploading onto the Phoenix board over the ISP header (see below).
One can either use an original 6digit 7segment (or really 8segment if we include the individual decimal dots for each digit) TIL 393-6 retro-authentic bubble LED display from Texas Instruments, or the NSA 1166 from National Semiconductors as shown in the above picture. As these are hard to come by, it is also possible to use a CL3061AG or SH3661AS modern LED display and an adapter (provided here as well):
Original Microtronic Firmware
The original Microtronic firmware can be found here.
The files are provided for reference and interest only, and are not required for programming the Phoenix firmware. The Phoenix firmware sketches are self-contained, and the Microtronic firmware ROM image is embedded on the code-level (instead of on the file level) in them.
Emulation Modes - NEO vs. PHOENIX
The Phoenix offers two Microtronic emulation modes:
- the Neo Mode is based on Michael's Arduino-based re-implementations of the Microtronic in C, and similar in spirit to the Retro-Authentic Bubble LED Display Microtronic.
- the Phoenix Mode is based on Jason's breadboard Microtronic running the original Microtronic ROM on his TMS1xxx emulator.
The Phoenix is offered with three different firmwares:
Neo Only: only offer the Neo Mode (describe below).
Phoenix Only: only offer the Phoenix Mode (described below).
Combined: should be the default; this offers both modes; upon boot or reset (via the
RESET
button), the user can select the firmware of choice for the "Phoenix OS" - "P OS ?"; here, push 1 for NEO, and 2 for PHOENIX:
Common Hardware Features
The Phoenix board offers a number of additional hardware features, in
particular, an on-board buzzer, and 4 additional push buttons DIN1
to DIN4
The original Microtronic came with a buzzer as well as two push button ("G" and "H") which, in many experiments, where connected to the digital inputs (DIN), and the buzzer was usually connected to either DOT Output 1 or 4, as shown in this picture:
The Phoenix board hence offers these on-board, for convenience (plus
two extra-buttons, DIN3
and DIN4
). The on-board buzzer can also be
disconnected via the BUZZ
DIP switch.
Moreover, both the Neo and Phoenix mode support the CPU speed buttons:
emulation speed can be decreased (CPU-
) and increased ( CPU+
). The
RESET
button works in both firmwares as well:
Neo Mode
In Neo Mode, the hardware emulator has access to the additional hardware features on the board:
a speaker for sound output: like in previous Microtronic emulator versions, vacuous op-codes are used as sound op-codes.
an 256 kBit 24LC256 EEPROM for mass-storage of Microtronic RAM dumps, instead of the 2095 cassette interface. The EEPROM has enough space for 42 complete memory dumps. It is accessed via
PGM 1
andPGM 2
. NOTE: to save to or load from the EEPROM, thePROT
ect switch must be in OFF position!. Turn thePROT
ect switch back on after EEPROM operation. See this picture:Please note that the
CARRY
LED will not work properly with thePROT
switch in OFF position. -
the speaker is also used for key beeps; the
BEEP
button is used to turn on or off key beeps. -
7segment status display: with a suitable 7segment LED display that offers controll over the individual digit decimal dots (the NSA 1166 from National Semiconductors does not, but the TIL 393-6 from TI does), the 6digit 7segment display also indicates the CPU emulator state, as well as the
CARRY
,ZERO
, and1 Hz
CLOCK flags (in addition to the LEDs on the board). TheBEEP
button is used to turn on or off this status display - this is a feature which is independent of the display's main function as the primary visual user interface.The status decimal dot LEDs are, from left to right:
- Dot on digit 6: program running
- Dot on digit 5: requesting user input (
KIN
active) - Dot on digit 4: breakpoint active (
BKP
) - Dot on digit 3:
CARRY
flag - Dot on digit 2:
ZERO
flag - Dot on digit 1:
1 Hz
clock
The NSA 1166 only supports control of the decimal dot for digit 3; hence, only the
CARRY
flag can be visualized with it.It should again be noted that, if in OFF position, the
PROT
ect switch disables the mainCARRY
flag LED (left to the 7segment display). However, utilizing the secondCARRY
flag indicator (the decimal dot of digit 3) we can hence leave thePROT
ect switch in a permanent OFF position without loosingCARRY
flag visibility. And, this also works with the NSA 1166.Also note that two NSA 1166 / TIL 393-6 adapters are provided in this repo (see picture above): one for the CL3061AG display, and one for the SH3661AS diplay. The bubble LED display are getting very hard to source these days.
The Neo firmware contains the following PGM
programs; these are:
PGM 1
: Load program from EEPROMPGM 2
: Save program to EEPROMPGM 3
: Set clockPGM 4
: Show clockPGM 5
: Clear memoryPGM 6
: LoadF01
(NOPs) into memoryPGM 7
: Nim GamePGM 8
: Towers of Hanoi (up to 4 disks - see https://github.com/lambdamikel/towers-of-hanoi)PGM 9
: Electronic Die (Microtronic Manual Vol. 1, page 10)PGM A
: Three Digit Counter (Microtronic Manual Vol. 1, page 19)PGM B
: Moving LED Light (Microtronic Manual Vol. 1, page 48)PGM C
: Digital input DIN Test ProgramPGM D
: Lunar Lander (Moon Landing) Game (Microtronic Manual Vol. 1, page 23)PGM E
: Prime Numbers ("Computerspiele 2094", page 58)PGM F
: 17+4 BlackJack Game ("Computerspiele 2094", page 32)
Note that, on the original Microtronic and hence in Phoenix mode, PGM 0
performs a self-test, and PGM 1
and PGM 2
are used to access
the 2095 Cassette Interface, which is currently not supported by the
Phoenix board. Instead, PGM 1
and PGM 2
are used to access
the EEPROM.
Moreover, there are no PGM
demo programs 8
to F
in Phoenix mode.
Phoenix Mode
In this mode the system behaves identical to the original Busch Microtronic, executing the original Microtronic firmware using Jason's TMS1600 emulator! Hence, the original Busch manuals are the best documentation. It is currently only available in German, but contemporary GenAI technology will likely have little problems translating it to English.
Note that the Phoenix runs ~ 30 to 40 % faster than the original Microtronic, but still significantly slower than in Neo mode at max speed.
The digital inputs and outputs are fully functional, and even the
original PGM 1
and PGM 2
firmware ROM programs are working.
They can be used for accessing the 2095 cassette interface
emulator.
Here is a video demonstrating operation of the original 2095 cassette
interface, and a 2095 emulator
tutorial by "Mein Elektronic Hobby" (in
German) for first steps with
PGM 1
and PGM 2
Moreover, unlike the Neo version, the self-check PGM 0
firmware ROM
program is functional, and can be used for checking proper operation
of the system, see User Manual Vol. 1, pp. 5 -
6
(note that a test harness is required for PGM 0
operation).
Please note that the RESET
button is supported, but the CPU-
CPU+
, and BEEP
buttons are non-functional in this mode. They only
work in Neo mode.
Combined Mode
This should be considered the default firmware - it combines the features of the Neo and the original firmware.
In addition to the individual features of the Phoenix and Neo modes as just described, the combined mode realizes one more essential synergistic feature making this mode more than the sum of its individual modes: shared Microtronic program memory! In this way, the Phoenix mode can take advantage of the additional features of the Neo mode, like EEPROM access or additional PGM demo programs.
For example, to load a program from EEPROM into Phoenix, we would
- start in Neo mode, load a Microtronic program from EEPROM via
PGM 1
. - switch to Phoenix mode: push
RESET
, enter2
. - the same program is now available in Phoenix mode.
In general, all changes made to the current Microtronic program in memory will always be available to the other mode as well.
You can also load one of the additional demo PGM
s easily into Phoenix mode.
PGM
ROM program, for example, "17Add4 Blackjack":HALT-PGM-F
RESET
, enter2
. - play Blackjack in Phoenix mode:
HALT-NEXT-0-0-RUN
The Phoenix Board
In principle, the Phoenix is a one-chip design - everything is driven by the ATmega 644P-20U, even the display. The 24LC256 EEPROM is optional; the machine will also work without it. The 74LS244 is used to electrically decouple the Microtronic inputs and outputs from the ATmega and make it more robust for experimentation in case an experiment goes awry. It is cheaper and easier to replace the 74LS244 than the ATmega.
Phoenix Power Supply Options
There are four options of powering the Phoenix board:
With a 9V block battery. The power switch must be in ON position.
With an external 9V to 15V DC power supply over the standard center-positive 2.5 mm power jack. A 0.5A supply is sufficient. The power switch must be in ON position.
Over the
VIN
andGND
rivet sockets. The power switch must be in ON position. -
Over the AVR ISP header. In this case, the power switch should be in OFF position!
For options 1 to 3, a 7805 voltage regulator is used to down-regulate the input voltage to the required 5V level.
Note that it is not necessary to remove the 9V battery from the Phoenix if another power supply option is used - a standard 1N4001 rectifier diode prevents all current flow (and hence "charging" attempts) into the 9V battery from the external power supply.
Phoenix VCC
, VIN
, and GND
Outputs
For powering electronics experiments with Busch electronics kits
and/or breadboards, the Phoenix board can supply 5V via VCC
as well
as 9V from the battery (or any voltage that the external power supply
provides) via VIN
. The power switch must be in ON position to access
these voltages. Both VCC
and VIN
are available from rivet sockets
as well as pin headers.
Display & Flags
The 6digit 7segment LED display is the primary visual output channel of the Microtronic. It should be fitted with a red (or green) lens filter to enhance the contrast.
Left of the display are the CARRY
and ZERO
flags. Note that the
CARRY
LED will only function if the PROT
ect DIP switch is on ON
position. However, the NEO mode can utilize the decimal dot of the
third display digit from the right to visualize the CARRY
flag as
well.
Inputs & Outputs
The Microtronic input and output ports are available in two form form factors: as pin headers for DuPont cables (breadboard friendly), and via classical Busch metal rivet sockets for the little yellow connector pegs:
These are the Microtronic outputs (they are controlled via the DOT
Data Out op-code); note that GND
is available via a rivet socket,
and the 1 Hz
clock signal from the pin header:
There are LEDs for the 4 Microtronic outputs, as well as an LED for
the 1 Hz
clock output.
The Microtronic inputs (they can be read with the DIN
= Data In
op-code) are available as pin headers and rivet sockets as well; also
note the 1 Hz
clock rivet and corresponding LED, as well as the
power supply socket rivets for external circuits / experiments:
Additional Hardware Features
The additional hardware features of the board have already been
discussed: the buzzer, the speaker, and the DIN1
to DIN4
buttons. The buzzer can be switched off with the BUZZ
DIP switch.
Phoenix and the 2095 SD Card-Based Cassette Interface Emulator
The hardware emulation of the Phoenix is faithful enough to allow
interfacing with the 2095 cassette interface
emulator.
Despite the availability of the much more comfortable EEPROM for
program storage, this is of some practical utility, as .MIC
programs
can be loaded from and stored to SD card, and the FAT32 file system
facilitates convenient data exchange with the PC or Mac. Programs in
.MIC
format can be found
here,
and loaded into the machine with the 2095 emulator, and then stored to
EEPROM as well, saving the user from having to type these in.
Unfortunately, it is not possible to use the real 2095 interface and cassette recorder, as Phoenix does not generate the required 32.768 kHz clock signal that is the basis for the tone generation that encode the 0 and 1 bits via Frequency Key Shifting on the 2095. The 2095 schematics - reconstructed by Frank de Jaeger - can be found here; there we can see that the 32.678 kHz signal generated by the Microtronic provides the Phi1 clock signal to a CD4060 14-Stage Ripple-Carry Binary Counter/Oscillator.
Bill of Material - BOM
- U1: ATmega 644P-20U + 40 Pin DIP Socket, 20 Mhz crystal and matching capacitors (2x 22 pF)
- U3: 74LS244 + 20 Pin DIP Socket
- U4: 7805 + matching capacitors (e.g., 2x 22 uF electrolytic)
- U6 (optional): 24LC256 + 8 Pin DIP Socket
- DOT1-DOT4, CARRY, ZERO, 1HZ: 3mm diffused red LED of your choice, e.g., https://www.amazon.com/dp/B0DN1LXQYH
- 1N4001 Rectifier Diode
- R1..R4: 4.7 k
- R5..R9: 1 k - these should match the DOT1-DOT4 and 1HZ LEDs; for modern low-power LEDs such as the ones linked above, 1 k is quite bright (4.7 k might be better)
- R10..R11: 1 k - these should match the CARRY and ZERO LEDs; for modern low-power LEDs such as the ones linked above, 1 k is quite bright (4.7 k might be better)
- R12: 100 Ohm - should match the buzzer (reduces volume)
- R13: 75 Ohm - should match the loudspeaker (reduces volume)
- R14..R20, R22 : 1 k - shold match the LED display
- R21: 10 k
- Speaker (optional): https://www.amazon.com/dp/B07LGKSRCK
- Buzzer (optional): https://www.amazon.com/dp/B01N7NHSY6
- 3-Position DIP Switch: https://www.amazon.com/dp/B0CSN9XDG5
- 5.5x2.1 Barrel Power Jack: https://www.amazon.com/dp/B081DYQSC9
- 6x6x5 Push Buttons: https://www.amazon.com/dp/B01CGMP9GY
- 6digit 7segment LED display with Common Cathode: https://www.aliexpress.us/item/3256803561087338.html, or TI TIL 393, NSA 1166
- 3x 103 (100 nF) capacitors (or 3x 104 / 1 uF - doesn't matter that much: https://hackaday.com/2025/01/25/capacitor-decoupling-chaos-and-why-you-should-abandon-100-nf/)
- breakable PIN headers, 2.54 mm pitch: https://www.amazon.com/HiLetgo-20pcs-2-54mm-Single-Header/dp/B07R5QDL8D
- 9V battery holder box: https://www.amazon.com/dp/B07Q1N2MHT
- Metal rivets: https://www.digikey.com/en/products/detail/keystone-electronics/46/316215
- M2 screws + nuts + washers: https://www.amazon.com/dp/B0BX96SMW4
- Mounting feet: https://www.amazon.com/dp/B07DHHS1Q8
- USPasp: https://www.amazon.com/dp/B0885RKVMC
- Heatsinks for the 7805 (optional): https://www.amazon.com/dp/B0CG91KN14
Gerbers
The Gerbers for the Phoenix board
and for the display adapter
are available:
Phoenix Firmwares
The firmware requires the Arduino IDE and a proper installation of MightyCore.
Firmware uploading / programming is done "in system" via the ATmega ISP header and, for example, USBasp:
Note that you will need to burn the bootloader with the correct
MightyCore settings first before you can compile and upload the .ino
Arduino sketch for the firmware variant of your choice (Combined,
Neo Only, or Phoenix Only, as described above):
Please note that you will need to install the NewTone
library from
Tim
Eckel.; a
copy is included here for
convenience.
The 7segment LED glyphs / fonts are Ricardo Batista's TM16xxFonts.h; a copy is included here for convenience.
Microtronic Software
A great new fun Microtronic software project is the "Monarch" rotary slot machine by rab-berlin:
https://github.com/rab-berlin/Monarch2090
Moreover, most of the historical Microtronic programs from the
Microtronic manuals can be found
here,
in .MIC
format.
Michael has some Microtronic programming videos online; the highlight is an implementation of a recursive version of the infamous "Towers of Hanoi" (yes, recursion on the Microtronic is possible!).
Acknowledgements
This project benefitted tremendously from the following individuals; we are very grateful for your contributions to this project! In particular,
Jörg Vallen:
The co-designer of the Busch Microtronic, author of the Microtronic manuals, and CEO of Busch Modellbau, Mr. Jörg Vallen, was very supportive and encouraging of this as well as past Microtronic-related projects - not only allowed he to include the original Microtronics manuals and schematics, but he also gave us permission to publish the firmware ROM and firmware disassembly as well (disassembled by Decle's TMS1xxx disassembler and hand-corrected by Jason) - THANK YOU:
Von: Jörg Vallen <....@busch-model.com> Gesendet: Freitag, 21. Juni 2024 10:37 An: 'Michael Wessel' <.....@gmail.com> Betreff: AW: Neues Microtronic-Video aus dem Saarland Sehr geehrter Herr Wessel, ... Finde ich genial, dass Sie auch das Betriebssystem ausgelesen haben. Natürlich dürfen Sie gerne das Betriebssystem auf der Microtronic-Github-Seite veröffentlichen ... Ihnen alles Gute und weiter erfolgreiches microtronicen… Viele Grüße Jörg Vallen
Third-party Arduino libraries:
Contributors to the Microtronic Neo predecessors include:
- Frank de Jaeger: 2nd Generation Microtronic PCB
- Manfred Henf: 2nd Generation Microtronic 3D Design & Printing
- Martin Sauter: Busch 2095 Cassette Interface Protocol Reengineering & Research
- Lilly (https://github.com/ducatimaus/Busch-2090): Breakpoint & Single Stepping Integration for Uno R3 Version
- Björn Rathje:
HXDZ
op-code bug fix (overflow set to 0 behavior),DISP
op-code bugfix
The YouTube channel "Mein Elektronik Hobby", who demonstrated PicoRAM-2090 (also see https://github.com/lambdamikel/picoram2090) as well as the 2095 Tape Interface / Tape Emulator (joint work with Martin Sauter).
Thank you all!
