The button works like a trigger fro the bus stop. When you press the button it lets the bus driver know that you want to get off at the next stop. It will have a sensor to connect to whatever bus you are on.
We had to remake the dimensions of the outer layer because we found out that the dimensions were very off I will send the picture of the updated prototype.
